Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-08-2008, 11:58 AM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 is gaining momentum as a positive member of FTE.
Factory tach??
Was a factory tach installed in the 95/96 E series vans? I have a 95 E350 bus conversion and would like to get rid of the aftermarket tach sitting in the middle of the dash that a prevous owner install.
  #2 (permalink)
Old 12-08-2008, 01:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
There was no factory tach in the vans until either 2004 or 2005.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #3 (permalink)
Old 12-08-2008, 06:46 PM
Thanks, guess I'll relocate the aftermarket one then.
  #4 (permalink)
Old 12-16-2008, 01:59 AM
neil 95 e350 neil 95 e350 is offline
neil 95 e350 is starting off with a positive reputation.
i fit an ~3" VDO tach just to the right of the left side (driver's) dash vent - so it is left of the speedo. if you can deal with a 2 1/8" tach, order the aftermarket Superduty upper steering column cover that has a gauge pod built in - slips right over the factory piece. i did and use it for my second battery system voltmeter (i run 2x200A alt setup) but you could use it for the tach and not have to cut the dash panel insert. i would have but i happened to have the tach and not much $$.
neil in san marcos
  #5 (permalink)
Old 12-16-2008, 02:58 PM
rclarke rclarke is offline
rclarke is starting off with a positive reputation.
My solution is a "Scangauge II" Do a google search for more info but I like having all the other functions available.
  #6 (permalink)
Old 12-16-2008, 04:25 PM
While at the junkyard the other day, I was courious about the F-series cluster of that age range. The physical cluster's are diffrent but the wireing harness were the same to both E and F series trucks from what I can see. I might try to modify a F-series to fit into the van dash. At least the POSD speedo's are the same, may have to rewire the connectors for compatiblity.
Any thoughs and if possable a wire schematic for the 95/96 E350 van with RV package?
  #7 (permalink)
Old 12-16-2008, 11:31 PM
bkaser90 bkaser90 is offline
bkaser90 is starting off with a positive reputation.
any options for a tach for the 6.8 v10? I can't seem to find one.
  #8 (permalink)
Old 12-18-2008, 07:37 AM
hvac guru hvac guru is offline
hvac guru is starting off with a positive reputation.
Quote:
use a scan gauge 2,i have mine showing water temp trans fluid temp,intake air temp,and mpg
  #9 (permalink)
Old 12-18-2008, 03:45 PM
On My 95(96 titled) build date ,E350 460/e4od is not OBDii. Does Scan gauge2 work with it?
  #10 (permalink)
Old 12-18-2008, 03:55 PM
neil 95 e350 said "...second battery system voltmeter (i run 2x200A alt setup)..."
Hows the 2nd alt installed? On my E350 Bus, it has the rear Carrier AC unit that is ran off a 2nd A/C compresser with the Alt/smog pump belt. I noticed when all A/C units(cab and rear) are on, thats one heck of a draw even for the 130A alt thats installed! 3 condenser fans for the rear unit alone pull close to 50A !! Would like to install a 2nd Alternator to charge up the coach Batt and run the rear AC unit fans. My Dad also wants to know as he wants a 2nd Alt for his motorhome too.
  #11 (permalink)
Old 12-19-2008, 01:56 PM
Quote:
does it have a diagnostic port under the steering column?
  #12 (permalink)
Old 12-19-2008, 03:26 PM
No, just the connector under the hood.
  #13 (permalink)
Old 01-02-2009, 02:59 PM
Quigoline Quigoline is offline
Quigoline is starting off with a positive reputation.
I found an F series gauge cluster w/ tach on e-bay for $50.00...these bolt right up to our bezel....the wiring dia. I got on-line....you have to switch some wires around but it is well worth it to have the factory look
  #14 (permalink)
Old 01-03-2009, 11:57 AM
Quigoline, do you have the wireing info avliable?
  #15 (permalink)
Old 01-04-2009, 01:47 PM
wiring dia.
Hey, I forgot to mention I pulled out my 5.8 gas and dropped in the 7.3 PowerStroke Diesel
I used 2 sources... Wirediagram.com...not very good
then I used Alldata...but you need to have an account....($24.95)
I used 1995 E-350 ( my van & the year of my donor van)
Then I used 1995 F-250 (the year of my cluster W/ tach)
My new "tach" cluster was from a standard trans. truck....easy to convert (1min) with shift indicater from YOUR cluster.
Diagram states "gas & diesel"...cluster must be right for diff. RPM range and fuel gauge markings...Tach is powered off of ECU or PCM (forgot, been a while) Also states "8 cyl. only"
Once you learn to use AllData it is incredible the amount of info
I could fax you what I have if the years are the same, good luck,
Al
Tags
150 , 2008 , cluster , diagram , explorer , factory , ford , guage , rord , schematic , superduty , swap , tach , thunderbird , vdo , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
