Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 10-23-2009, 04:47 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 is gaining momentum as a positive member of FTE.
I got my cluster for $20! and thats with the harness I cut out of the junk truck, if I didn't cut the wires I would of been $15. I might be heading back up there next month when the fresh stuff comes in and hope more are there.
Thanks Bill, but I finaly got the info when I got a deal on some Mitchell manuals, picked up about 50 of them from 1979 to 1999? or 2001? for domestic vehicles and imports! Got them all for $25. Wished the transmission manuals were there but the electrical manuals were worth it.
__________________
89 F250 2x4 302/AOD 4.10 gears ,now on road.
89 Bronco2 with dead A4LD again
84 F250 4x4 300/np435 3.55 gears. The BLUE MULE shut down due to cab cancer(looking for good cab)
95 E350 bus conversion 460/E4od 4.10 the new toy!
85 Plymouth Caravelle 2.5L someday to get the hairdryer treatment(turbo)
93 explorer now just a woods buggy
  #32 (permalink)
Old 11-02-2009, 12:25 AM
sphinx's Avatar
sphinx sphinx is offline
sphinx is starting off with a positive reputation.
Quote:
Originally Posted by neil 95 e350 View Post
yeah eddie, i have already done mine when i pulled the cluster apart to add indicator led's for all the extra functions going on in my van. just wondering about other folks. i've been turning wrenches for 35+ years and owned this van since '96 and it took me until last year to realize out what ford had done - never thought about it until i really looked at it on purpose...
neil
Where is the resistor located?
  #33 (permalink)
Old 11-02-2009, 04:01 PM
The oil gage resistor is on the back of the insterment cluster's printed circut board. Its usually a 20ohm resistor (color coded:red black black gold) and its near by the oil gage it self inline with the sensor wire. Sometimes there is a lable calling it a 20ohm. just jumper it out with wire and get a sending unit for the older applications with gages. I have done this with all my later Fords and it works
__________________
  #34 (permalink)
Old 11-02-2009, 10:14 PM
sphinx's Avatar
Quote:
Thanks, I actually remember seeing it on my super duty when I was changing bulbs and wondering why it was there.
Guess that would also explain why the 4.6 in my 01' Mustang disassembled itself while telling me it had good oil pressure. Sure was glad it was under warrantee.
Can you remember what vehicle you got the sender for?
  #35 (permalink)
Old 11-03-2009, 04:39 PM
I recall , oil sending unit from 87 and older with gages should work. I think in 88 is when Ford did that stupid change over. On my setup with my 89 F250, I had to use the 87 dash,harness, engine/tranny as the the 89 was hacked up badly. So in one way I have a 89 chassis with 87 guts. All was bolt on swappable. The 89 cluster had the tach and 87 did not, simple swap, but I forgot about the oil gage resistor, so the gage always read low till I bypassed that 20ohm resistor, now fully working oil gage.
__________________
  #36 (permalink)
Old 11-03-2009, 06:36 PM
sphinx's Avatar
Thats what I needed to know.
THANKS
  #37 (permalink)
Old 11-09-2009, 09:23 PM
I just refound this info I had stuffed on my HDD.
Ford Oil Pressure Gauge Fix
With pix and more detailed info too.
__________________
  #38 (permalink)
Old 11-14-2009, 08:52 AM
jcbx jcbx is offline
jcbx is starting off with a positive reputation.
Hi All
anyone that can guide me thru this riddel ?
Have an ´92 E-line with theese wire setup :
and need to convert them into this setup as I have an ´94 F-serie 4x4 instrument (I think)
The new cluster has this number I guess :
also ! whats the small print doing that sits here normaly and can I mowe the old one into this space ?
all help is appriciated and thanks in advance !
Sincerly
JCBX
  #39 (permalink)
Old 11-14-2009, 10:40 AM
ohh, got to resize those pix! too big for my screen. You said you have a 92 van and have a 94 pickup cluster you want to install?
When I did my swap I did have the harness to the 94 cluster I cut from the JY, I just swapped over the wires on my 95 van to the correct color order for the 94 cluster.
IF you don't have the harness for the 92, I'll have to dig around for that info. Hopefully the color codeing will be the same bewteen the years as it was for me.
You will have to add a tach wire as the van's never had that option. Thats probly the most simple thing in the swap.
Ok, after resizing my screen, The photos are of the 92 van harness? I still have the 94 F-series harness with my old cluster and I can take some photos of the wiring so you can match up
what wires go where on your 92 van. I wished I took a photo of my van before I did the harness change over, that would of been helpful.
If you could, take a photo of the 94 cluster rear and the 92 cluster rear so I can compaire them?
__________________
  #40 (permalink)
Old 11-14-2009, 02:16 PM
Hi
The 4 first pictures are the ´92 wirring !
the next 4 are the ´94 wirring and must be the thread in this matter ? or ...?
it has colours that arent in the ´92
then 1 pict to where the small print sits ... whats the purpous of that print ?
and a pict of the number of the cluster ...
Thanks in advance
Sincerly
JCBX
  #41 (permalink)
Old 11-14-2009, 03:55 PM
What I did was match the van's harness wires to the F-series cluster. You see inside the connectors there is a red keeper, pull that out and you will be able to press a small locking pin on the wire connector itself and it will pull of the big connector.
Yep you will be moving a few wires around and some on the 94 will not be used at all(mostly the 4x4 indicators and few others. As long as your color codes are the same bewteen the years you should have no problems. Ah, whats the engine of your van? I'm going to dig up the wiring diagram for the 92 van for you.
__________________
  #42 (permalink)
Old 11-14-2009, 04:27 PM
Ok, got the wiring info for you. the first batch of schematics/connectors are for the 92 E-series van
__________________
  #43 (permalink)
Old 11-14-2009, 04:28 PM
Heres for the 94 Fseries cluster.
Hope this helps you out!
__________________
  #44 (permalink)
Old 11-15-2009, 12:58 AM
HI
thanks for the diagrams ! going to look it over today and hopefully it helps me thru
do you have a clue to me to where I pick up the 8cyl signal
I think it needs to be a + signal but from witch core at the dist. section
Thanks in advance
Sincerly
JCBX
  #45 (permalink)
Old 11-15-2009, 01:28 PM
HI
got it all in place today !
a bit unsure if my fuel level is going to show correctly .....
there is af difference in between the '92 E-line cluster and the (appers to be) ´92 F150 4x4 cluster
can anyone tell me what this small electronic device is doing and why its missing in the ´92 F150 cluster
'92 E-line cluster :
the ´92 F150 cluster hasnt this electronic device
I had to search F2TF-10C956-B witch is stated on the back of the cluster
and got this : http://www.ford-trucks.com/forums/87...e-diagram.html
seems like another guy had problems with the same cluster .......
of all clusters .... has I the wrong one or is it just me ?
anyway I used the last diagram posted in that section and it was spot on my cluster !
switched around some wires and needs to figure out the 2 tacho wires ... where they have to go .....
! but REALLY afraid that my fuel level is wrong .... any thourghts ??
anyone with info conserning the fuel level and wirring of the tacho ....
Thanks in advance
Sincerly
JCBX
Tags
150 , 2008 , cluster , diagram , explorer , factory , ford , guage , rord , schematic , superduty , swap , tach , thunderbird , vdo , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
