Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 01-05-2009, 06:16 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 is gaining momentum as a positive member of FTE.
Could you scan it in and email Quigoline? My van is a 95 E350 (96 titled) bus conversion with 460/e40d.
Could you clear up on how the cluster from the f-series was install to your e-series dash. Or did you swap out the guages from one to the other? Got me thinking of a junkyard run now....!
  #17 (permalink)
Old 01-05-2009, 09:16 PM
MADVAN's Avatar
MADVAN MADVAN is online now
MADVAN has a good reputation on FTE. MADVAN has a good reputation on FTE.
Up to the 96 its not bad to install the tach.
Just gut the f-tach section and install it in the e-cluster.
97 on up is a bit more work.
Here is a F-cluster in a 97 E-Quig diesel.
Bill
__________________
97 4X4 PSD Quigley
www.fordtransmissioncure.com
www.racerxautomotive.com
  #18 (permalink)
Old 01-06-2009, 06:11 PM
Quigoline Quigoline is offline
Quigoline is starting off with a positive reputation.
scan
I'm alot better with a set of wrenches than a keyboard and mouse but.....I'll give it ago asap...my E-350 started out 2wd...now it's a Quigly clone (also used a donor van... 2 yrs ago)
as far as the swap goes...the whole gauge cluster is in the same size and shape housing as our E cluster...our battery and fuel gauge is moved to the left of the speedo.. (all four gauges are to the left of the speedo)..just the tach to the right ....just like Bill's picture.
After removing the bezel assembly unplug three?? harnesses, take out four ??screws from the back and re-install the F series cluster on the back of your bezel....simple...(for some room to work I left the bezel off till I had everything functioning properly)
the wiring ( moving wires around in your pin connectors ) cross referencing colors and funtions...took alittle time...no Buds that day...notepad..
what be that e-mail address should I be able to scan these pages???..(worst case my grandkids will be around this weekend..someone has to know how to send them to you)
Happy hunting...Al
  #19 (permalink)
Old 01-07-2009, 06:07 PM
A PM(privite message) has been sent to you Quigoline.
  #20 (permalink)
Old 01-07-2009, 07:18 PM
MADVAN's Avatar
Link for IDI setup that was done.
Instrument Cluster
Bill
__________________
97 4X4 PSD Quigley
  #21 (permalink)
Old 01-09-2009, 03:27 PM
neil 95 e350 neil 95 e350 is offline
neil 95 e350 is starting off with a positive reputation.
here's what i did...
but gotta say the F series into the E series is so much cleaner... nice job!
  #22 (permalink)
Old 01-09-2009, 03:38 PM
btw, have many of you van owners fixed the oil pressure gauge really just being a low pressure switch?? that is to say that your gauge is not showing real oil pressure - the engine only has a low pressure switch normally used for a warning lite. ford kept the gauge and added a resistor so the gauge needle moves to the middle position (roughly) when the engine is running...
neil
  #23 (permalink)
Old 01-09-2009, 04:32 PM
Good info on the cluster swap. Hopefully a 95 E350 is like yours. I put my vacuum gage in where your tach is installed, Neil. I found the vacuum gage at Harbor Freight on sale and it fits just a tad over the depression(2.25" dia I think)
I still can't post pictures here or not doing it right any help on that so I show what I have. I am going to make another gallery once I get the camera working again.
The oil pressure is a simple fix, I got the info from another web site:
"First, they changed the oil pressure sender (used with a real gauge) out for an oil pressure switch (used with an idiot light). Second, they added a fixed resistance into the sender circuit (a simple 20 ohm resistor seems to be what they used in all
of the cases I could find) so that the gauge would read at about half-scale any
time the oil pressure switch was active. The way to undo their "fix" is simply to reverse it - swap out the sender for a real oil pressure gauge sender, and bypass the fixed resistance so that the gauge reads normally. The interesting thing about these instrument clusters is that the gauge is still a real gauge, which is what enables you to make it work correctly. Other folks have writen pages on how to solve this problem in the Thunderbirds, and some have indicated you can
solve it on the Mustangs as well, so I'm inclined to believe it will work on any vehicle where
you can find and bypass the fixed resistor (20 ohm) in the circuit."
I haven't done that to my van and pickup yet, at least the van sending unit is right behind the doghouse on the 460 engine! my F250 is reading low allready as I have the true sending unit installed allready, just have to jump out that resistor.
  #24 (permalink)
Old 01-09-2009, 06:06 PM
yeah eddie, i have already done mine when i pulled the cluster apart to add indicator led's for all the extra functions going on in my van. just wondering about other folks. i've been turning wrenches for 35+ years and owned this van since '96 and it took me until last year to realize out what ford had done - never thought about it until i really looked at it on purpose...
neil
  #25 (permalink)
Old 10-17-2009, 09:21 PM
Update: good ole cash 4 clunkers supplied me a f-series cluster with tach!! Now the fun starts in installing it. I'll post photos of progress.
__________________
89 F250 2x4 302/AOD 4.10 gears ,now on road.
89 Bronco2 with dead A4LD again
84 F250 4x4 300/np435 3.55 gears. The BLUE MULE shut down due to cab cancer(looking for good cab)
95 E350 bus conversion 460/E4od 4.10 the new toy!
85 Plymouth Caravelle 2.5L someday to get the hairdryer treatment(turbo)
93 explorer now just a woods buggy
  #26 (permalink)
Old 10-18-2009, 01:24 PM
Ok, I got my cluster installed and fully working. I did have to change about 8 wires around for the cluster to work properly,
at least the wire color codes were the same from the years of 94 F150 to the 95 E350. Just matched up the
connectors(I did grab the F150 connectors, BIG help there) wires and added the tach feed to it.
Before photo
After
I did reinstall my POSM so I have the original milage and ratios. Also the anti slosh modual is a plug and play after you cut a trace(shorting bar)
Got rid of that tach mounted on the dash, found out it was reading about 200 to 500 RPMs LESS than factory tach!!
Also found out my RABS is malfunctioning as the orginal dash RABS lamp was burnt out......
__________________
  #27 (permalink)
Old 10-19-2009, 03:00 AM
jcbx jcbx is offline
jcbx is starting off with a positive reputation.
PS: dont forget the topclearance of bus .........................
  #28 (permalink)
Old 10-19-2009, 04:40 PM
Going to make that 10' top clearance and put more in line of sight. Hated the location and with new guage it would cover up the temp and fuel guages.
Prevous owners in the past did hit things as the whole top front shows alot of fiberglassing repair work on the inside!
__________________
  #29 (permalink)
Old 10-23-2009, 04:15 AM
how much did you pay at the junkyard for the instrument ?
they seems a bit expensive at the eBaY
Sincerly
JCBX
  #30 (permalink)
Old 10-23-2009, 04:28 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Originally Posted by Eddiec1564 View Post
Any thoughs and if possable a wire schematic for the 95/96 E350 van with RV package?
Try helminc.com for the wiring schematic.
Helm has printed all of Ford's literature since the 1940's.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
Tags
150 , 2008 , cluster , diagram , explorer , factory , ford , guage , rord , schematic , superduty , swap , tach , thunderbird , vdo , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
