Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-08-2008, 06:57 AM
flipklos flipklos is offline
flipklos is starting off with a positive reputation.
What makes for the HD Y?
What sould I externaly look for to know if my spare '60 F550 block is an HD?
Its 2 bbl, and looks identical to the one in my '64 F100.
I know the HD blocks had forged cranks, stouter rods, and sodium filled E-valves. Where sould I look for a casting NO:? Do I have to pop the oil pan?
  #2 (permalink)
Old 12-08-2008, 08:58 AM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 is starting off with a positive reputation.
The HD blocks had steel cranks AFTER 60 starting with the 1961 models C1TE part number.
HD engines had differences in earlier years such as a larger oil pan, high fan mount with usually a 5 blade fan, governor, and yes you are correct on the heads with sodium filled valves.
Kevin Bigwin
__________________
1956 Custom Cab Big Window. 272 Y block 3sp. See gallery. Kevin
  #3 (permalink)
Old 12-08-2008, 05:35 PM
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
You can compare the crankshaft flange at the rear to these diagrams supplied by J. Mummert: TECHNICAL
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #4 (permalink)
Old 12-09-2008, 11:25 AM
WALFORD'S 56's Avatar
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 is starting off with a positive reputation.
I am working on my 56 yblock which is listed as ''industrial'' and has larger oil pan and also governor. It is from a 56F600 caterpillar owned truck.
  #5 (permalink)
Old 12-09-2008, 04:59 PM
Arno F100's Avatar
Arno F100 Arno F100 is offline
Arno F100 is starting off with a positive reputation.
well if you aske me, you can take a look at the heads, it's easy to see if it's a bigger one.
The exaust flange boltz are not in on line on the bigger lincoln engines, on the smaller y-block ford they are in one line.
  #6 (permalink)
Old 12-09-2008, 06:00 PM
ArnoF100---wow nice 56!! I am building 1 meadow green now myself. I am working on my 272 and t98 4speed out of a 56F600 and it is listed as industrial/high fan /bigger pan/governor and other than that looks like the other yblocks I have--4 more and looking for a yblock rebuilder!!
Anyone know of a yblock engine rebuilder in NE OHIO/W.Pa. area? thanks
  #7 (permalink)
Old 12-09-2008, 06:15 PM
Arno F100's Avatar
@ waldorfs 56
What is that high fan meaning?
And where should this governor be?
  #8 (permalink)
Old 12-09-2008, 07:02 PM
Sam_Fear's Avatar
Sam_Fear Sam_Fear is offline
<--It's a truck!
Sam_Fear has a good reputation on FTE. Sam_Fear has a good reputation on FTE.
He is talking about differences between the MD and HD 292. The Lincoln Y is different again.
__________________
I'm nothing more than words on your monitor.
  #9 (permalink)
Old 12-10-2008, 11:05 AM
@ waldorfs 56
Hi Arno
The high fan is above the place where the small non industrial fan goes. (hard to explain) It sits higher.
Governor is on left rear side of carb between carb and coil
The fan is actually mounted on front of block at the heighth of the front crossover exhaust-pipe.
Bill
  #10 (permalink)
Old 12-10-2008, 11:11 AM
Oh---I am walford's56 not waldorf astoria---LOL HAHA!!
  #11 (permalink)
Old 12-30-2008, 09:48 PM
yalincoln2 yalincoln2 is offline
yalincoln2 is starting off with a positive reputation.
hi, the HD 292's were all 4bbl, usually in 700-750's, would have had to order it in a 500-600, lincoln y's were used in 750and 800, 58-64, super duty's in 850, 900, 950, and 1000's, 52-53 lincoln y's in f-8 only. 54-57 lincoln y's 800, 850, 900's. most early ford trucks 54-58 used 239-256 as standard and 272-292's were optional, truck parts manuals will tell you what engines were available in what size truck. i believe if you had some pull you could have ordered any engine available that year in your truck. in 63 you could have ordered a 427 in a pickup, i've seen the adds from ford. i don't know it all, in fact most people tell me i don't know anything, but i do know you will find out a lot from old ford truck parts manuals. just trying to help, wayne.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
