I want a Tachometer
Yeah. The Dynoscan SPD does the same thing too, and has a great digital gauge that can be setup as a tach.
Most do hookup to the negative lead. But I don't think you can hook into the coil pack directly. But I am pretty sure that there is a tach wire meant for diagnostics.
Just go to the tach manufacturers website. They have a lookup for wiring it. See if your model is listed and take a look at their instructions.
Can you not find a factory cluster with a tach included?Im not sure but would think that if its an OEM cluster,perhaps the truck harness might have the tach drive line already there?.(Salvage yard perhaps?)..Just a thought
ejstave
05-27-2009 07:36 PM
