Shifting into 4 wheel drive - Ford Truck Enthusiasts Forums
Old 12-06-2008, 10:51 PM
wxscoe's Avatar
wxscoe wxscoe is offline
wxscoe is starting off with a positive reputation.
I have a 2000 F150 Supercab 5.4L 4x4 auto tranny, with the 4 wheel drive shifter on the floor. All of the manuals I have read for it say this,
"Shifting from 2H (2WD high) to 4H (4WD high)
Move the transfer case lever to 4H
(4WD High) at a stop or any
forward speed up to 88 km/h
(55 mph)".
I've tried shifting into 4 wheel drive with the truck in drive, but stopped, and it just grinded when I tried shifting into 4 wheel drive. I stopped as soon as it started grinding! It shifts into 4 whel drive fine w/ the tranny in nuetral. Has anyone tried shifting into 4 wheel drive on the fly like the manuals say can be done?
Old 12-07-2008, 06:28 AM
jobofly jobofly is offline
jobofly is starting off with a positive reputation.
i do it all the time, im usually not going very fast, maybe 20-30, and it shifts very smmoth. but i have never had a problem like this.
Old 12-07-2008, 08:53 AM
Octane's Avatar
Octane Octane is offline
Octane is starting off with a positive reputation.
Perhaps you need to take your foot off the gas when you shift into 4x4. I know that on mine, it wont go into 4x4 if you have your foot on the gas. Mine has the **** on the dash that shifts it into 4x4 electronically though...
Old 12-08-2008, 12:18 AM
wxscoe's Avatar
jobo, do you have the 4x4 stick on the floor, or the electronic **** on the dash? If you do have the stick on the floor, do you put it in nuetral before shifting to 4 wheel drive?
Octane, I know you can shift into 4 wheel drive on the fly with the electronic 4x4. I have the stick on the floor.
I've never heard of being able to shift on the fly with this before.
Old 12-14-2008, 01:10 AM
bigralso's Avatar
bigralso bigralso is offline
bigralso is starting off with a positive reputation.
The only time it might grind is when shifting into 4WD low range on the move.\
To go from 2WD to 4WD high, on the move, you should only have to move the shifter about 1 inch straight down.
Also are all 4 tires the same size??
Old 12-14-2008, 07:04 AM
m350 m350 is offline
m350 is gaining momentum as a positive member of FTE.
It will grind if you are spinning the back tires,,,let of the gas,,so all wheels are moving the same speed,,it should go right in,,no grinding.
You must be stopped (well maybe rolling less then 1 mph),,,to go into low Range.
Old 12-14-2008, 08:13 AM
96f150's Avatar
96f150 96f150 is offline
96f150 is starting off with a positive reputation.
It sounds like maybe your vacuum shift motor(mounted on the front axle tube) may not be slding the front dif into 4 wheel drive all the way. I would have someone move the shift lever between 2H and 4H, while you look underneath and see how far the shift lever on the diff moves. You may have a vacumn leak if thats the case.
Rich
Old 12-15-2008, 11:53 PM
wxscoe's Avatar
big: all four tires are the same size, 265/70R17 Nitto Terra Grapplers
m: I've never tried shifting it while I was moving, so the back tires weren't spinning.
96: thanks for the info, I'll check that out. Like I said in my origianl post, I haven't tried shifting it on the fly, because I didn't think it was possible. I was just wanting to know if anyone's done this before I try it, so I don't jack anything up.
Thanks for all the info. this site is great!
Old 12-17-2008, 10:28 AM
wxscoe's Avatar
hey all. We finally got enough snow that I needed 4wheel drive, so I tried shifting on the fly, and it worked fine. Tanks for all the help.
E40D transmission/Ignition problem...Any advice would help FoMoCoFan52 1987 - 1996 F150 & Larger F-Series Trucks 13 04-03-2015 05:16 PM
60,000 transmission fluid change? awq134 2009 - 2014 F150 6 12-25-2014 01:50 PM
THIS is what ill be driving 351Cleveland C4 The Next Generation 23 09-23-2013 06:00 PM
Manual DPF Regen & Options Info pbruckne 6.7L Power Stroke Diesel 11 03-12-2013 12:35 AM
Changing Tire and wheel size Rickx 6.7L Power Stroke Diesel 7 10-12-2011 06:43 PM
Tags
1999, 2004, 2006, 2008, 2h, 4h, 4x4, 60, awd, drive, f150, f250, fast, ford, shifting, wheel, whewl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
