2001 F150 Cab Water Leak
I have a 2001 F150 and everytime it rains, I get a puddle on the drivers side floor mat. I have had it to the dealer and they did a "hose" test but found no leaks.
Have you had a similar leak in your truck. If so, what was leaking and how did you fix it?
Thanks,
Ron
Thanks,
Ron
I have the same problem
I have the exact same problem, water leaking down on to the driver side floor mat. I had to replace the heater core about a month ago, and found no sign of where the leak could be coming from, but now it seems to be leaking worse, and it seems to be causing some weird electrical problems. I have checked all around the windshield and under the windshield wiper vents and I have no clue. If anyone has an idea about where the leak could be coming from, you would have my thanks.
2001 f-150 super crew cab/4.6L v8
toledoslim2
09-29-2003 06:53 PM
