How to test IPR?
Update:
We put a scanner on the truck today and the IPR duty cycle never went above 25-30%. We talked to a Ford tech (I don't know how 6.0 savvy he way) who thinks its an injector. He thinks the injector gets stuck open and allows air from compression into the fuel system. This would explain why my original post how that air was getting into the fuel bowl.
Do you think this is a possibility? If so, is there a way to identify which injector it is (other than with a scanner)?
If an injector was stuck open it would hydro lock the motor in short order (50 psi of fuel pouring into the cylinder).If you were getting air in the fuel it would be a leaky injector sleeve or crush ring. Also while it was running with an injector stuck open the truck would smoke up the block in a minute with unburnt fuel.
I'd love to buy you a case of Molsons, or whatever your flavor is! I'm a Fat Tire / Sammie Adams guy myself.
We did a buzz test on the injectors and everything came back normal. However, we still haven't done the cylinder balance test. Hope to figure out how to do that tomorrow.
The smoke we're getting is almost clear, so it's hard to determine how much of it there really is. However, its extremely raunchy. It stinks up the whole shop quickly and it lingers for hours even with the exhaust fans on.
Tomorrow we're also going to put a heat gun on each cylinder and see if that doesn't identify any oddities.
Somebody else pointed out this little gem of a test. Might give this a go too. Then we should have the both injectors and HPO leaks covered.
Balloon Test
Balloon Test
A little more warning regarding removal of that setscrew in the HPO rail would have been nice. However, I lucked out. When the smoke cleared (i.e. I wiped the oil off my glasses so I could see), the little setscrew landed right on top of the oil rail about two inches from the hole. I had NO CLUE where that thing went after it popped loose. Hilarious, thinking back about it. However, I was extremely lucky that I was able to find it.
When I put shop air (>150psi) to the HPO system, it was quiet as a mouse. I heard no leaks whatsoever.
Got the balloon test done and #6 appeared to be the culprit. I wish I had used water balloons so they would have fit tighter around the fuel line. With the zip ties pulled as tight as I could get them, the balloon stayed limp on all cylinders, except on #6 it filled so that it wasn't limp anymore. Not an obvious leak, but a leak none the less. I have an injector on the way.
#30
