Instaslling a 460 crate engine
And look in the article/spec section in the start up sect
You need the engine mounts, the perches and the isolators specific to the 385 engine in a seventies truck. Or purchase an aftermarket set of mounts.
You also need a 351M/400/429/460 manual bell housing or a C6 Automatic with the same pattern.
A new radiator will also need to be sourced if the truck was a six or small block V8.
Garbz
The swap can be made with all ford parts if desired.
Garbz
luismadrigal
27
02-07-2016 09:10 PM
luis2171
05-28-2006 11:31 PM
wtlcruiser
03-07-2006 02:26 PM
Luis_3
08-12-2002 02:38 PM
