Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-06-2008, 12:32 PM
coop25 coop25 is offline
coop25 is starting off with a positive reputation.
whats the problem with svo in a 6.0?
i have a 6.0 f-350 its a 2005. what are the major problems or concerns with runnung svo if you start on diesel to warm the tank then switch to svo? dont the same priciples apply to a 6.0 then that of a 7.3 that has been successful on svo?
  #2 (permalink)
Old 12-06-2008, 01:36 PM
Pocket's Avatar
Pocket Pocket is offline
Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold
Depends on what you define as "success" with SVO, or even WVO.
There are right ways to run it, and there are wrong ways. The right ways are decontamination, filtration, and heating.
People who do the most damage running SVO typically skip on buying a heated tank. You must heat veggie oil to ~160 degrees F or so. If you don't, you risk injector coking, and eventual cylinder waxing and scoring. This affects all diesels, not just the 6.0L. The problem that people are realizing with the 6.0L, is that the injectors can be rather sensitive at times, compared to say the 7.3L.
Even if you do get a heated tank and run SVO properly, you will still find that a typical engine and injectors will not last as long as one that runs on straight diesel only. SVO does leave behind deposits, that is fact. Maintenance is key to making the engine last as long as possible. You will need to change out the fuel filter more often, as well as change oil more frequently than normal. It is also recommended to pull the injectors every 50K miles or less to inspect them for coking and damaged nozzles. Expect to change out injectors at 100K miles, sometimes less.
The trade off with those who use SVO sucessfully is that if your source of fuel is cheap enough, you will save so much money in fuel that you can buy another engine when yours craps out, and still have extra cash left over in your wallet. Just don't expect many engines running SVO to make it to 300K miles.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
Truck Pics
Quote:
The phrase "It'll make a turd" is not considered a compliment when referring to the quality of dinner.
  #3 (permalink)
Old 12-07-2008, 11:12 AM
petebal petebal is offline
petebal is starting off with a positive reputation.
my report
been running svo for nearly two years now (Veggiestroke - Classic Series) ...this is my latest report from Blackstone...oil is changed every 5K.
"Wear is as good as we've been seeing so there were no changes this time that would suggest any new problems for
this 7.3L Power Stroke in your F-250. Wear metals are slowly creeping up from what we were seeing back
in 2007, but at this rate, your engine is still on track to have a very long life. "How long?" you may ask. We
would not be surprised to see it easily last 300,000 miles and possibly a lot longer than that. Still no
anti-freeze or excess soot present. Nice report."
  #4 (permalink)
Old 12-15-2008, 01:37 PM
nitrogen's Avatar
nitrogen nitrogen is offline
nitrogen is gaining momentum as a positive member of FTE.
i have heard that the glycerine is what forms most of the deposits and causes the injector trouble
__________________
2005 F350 Lariat crew 4x4
traded F350 XLT supercab 4x4 what a stinker
  #5 (permalink)
Old 01-28-2009, 02:04 PM
JOEOIL JOEOIL is offline
JOEOIL is starting off with a positive reputation.
in the cold is were all the problems happen.
switching of hot svo-wvo ,to ice cold dino-diesel.
heat the dino,add lubricant,
two seperate fuel filters, one just for dino,one heated just for svo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
