2000 Ford F250 Oil Leak Please Help! - Ford Truck Enthusiasts Forums
Old 12-06-2008, 07:30 AM
bigbadpowerstroke bigbadpowerstroke is offline
bigbadpowerstroke is starting off with a positive reputation.
I have a 2000 Ford F-250 4x4 6spd. 7.3. 125,000 miles. My truck has developed an oil leak from one day to the next. I need help solving the problem. The (motor) oil is leaking from the two breather holes or clutch inpection holes under the transmission on the bellhousing. Im thinking my rear main seal is out or there is a oil coming somewhere from where the tranny and motor bolt up. It has to be from there and i know there has to be oil on the clutch cause its slipping and never has slipped before. If any one could help or have encountered this leak or problem with a 7.3 and know what i talking about i would really appreciate the help and the assurance please reply. I really like this forum there is alot of people on here that know their s**t when it comes to them 7.3's.
Thank You
Lucas
Javelinas06@aol.com
Old 12-06-2008, 07:52 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
welcome to FTE
i will bet if you look into the valley of the motor up top..you will find a big puddle of oil..clean it all up..start her up and look to see where it is coming from..
Old 12-06-2008, 07:55 AM
Texas Outlaw's Avatar
Texas Outlaw Texas Outlaw is offline
Not a liberal...
Texas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant future
I'm not a 7.3 guru by any means but I do have some experience with an oil leak similar to yours. First thing to do, is to climb up on top of the motor with a flashlight and check to see if there is oil puddled in the valley of the motor. This is behind and below the fuel bowl housing. Check all the way back. My bet is that you do not have a leaking rear main seal and instead have a leak up on top. The oil is running down the backside of the motor and exiting to the ground through your inspection plate. Mine did the same thing. Ended up being an HPOP o-ring.
Do what I described and then post back what you find. We will figure this out together.
Old 12-06-2008, 08:07 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Welcome to FTE.
And......
What they said.
The rear main seal very rarely ever goes out, but is dripped upon from something above it.
2000 Ford Expedition xlt battery saver relay clicking no start websurfer 1997-2006 Expedition & Navigator 13 11-14-2016 03:22 PM
How To: Replace Rear Wheel/Hub Bearings GregN Excursion - King of SUVs 25 05-08-2016 09:37 AM
BATTERY MAINTENANCE ? What you say! Thomas White 1999 - 2003 7.3L Power Stroke Diesel 4 07-11-2015 02:25 PM
Oil leak after exhaust manifold stud repair rbrad6937 Excursion - King of SUVs 4 01-15-2015 12:10 AM
Transmission wire harness HELP! charon61285 1999 to 2016 Super Duty 0 04-10-2014 02:21 PM
Tags
02, 2000, 73, 73l, f250, f350, ford, leak, leaking, motor, oil, power, sd, stroke, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
