serpentine belt broke
Old 12-05-2008, 05:34 PM
edsherman's Avatar
edsherman
edsherman is offline
There's radiator fluid leaking and the serpentine belt just broke. Is it just the belt? Or, do I have another issue that causes the radiator fluid leak?
thanks,
jason
Old 12-05-2008, 05:38 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
possibly waterpump leak
Old 12-05-2008, 05:57 PM
big poppa's Avatar
big poppa
big poppa is offline
Maybe when the belt broke it smacked one of your upper or lower radiator hoses? Check your hoses for cuts and welcome to FTE..
Old 12-05-2008, 08:34 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Powerstrokedlariat is offline
My thoughts as well. Welcome!!
Old 12-05-2008, 11:55 PM
twags6's Avatar
twags6
twags6 is offline
Where's the leak at? If its right below the water pump, it might be a sign that the pump is on its way out. If its splattered everywhere, the belt might have nicked the upper hose when it let loose.
Oh, and if you have the hose that goes through the belt, nows the perfect time to change to the one that goes around. Its the hose listed for the dual alternator setup. NAPA part number 9066.
Old 12-06-2008, 07:46 AM
machmedic's Avatar
machmedic
machmedic is offline
Like twags6 said, perfect time to upgrade upper rad hose to dual alt setup.
Old 12-06-2008, 08:43 AM
Calli's Avatar
Calli
Calli is offline
Possible waterpump froze up causing belt to break??? See if pulley turns.
mperl
2004 - 2008 F150
02-26-2017 04:24 PM
roller_steve
12-30-2016 02:41 AM
jhammond615
03-18-2010 07:53 PM
MJBEASL1978
06-05-2006 02:41 PM
aime
Aerostar
13
07-07-2003 05:36 AM
Quick Reply: serpentine belt broke
