if you are going to run
propane only, then my logic tells me since
propane is roughly the equivalent to 114 octane gasoline(minus some btu's), you should run about 10:1 compression to optimize the available
propane btu's. i would also go with an advanced curve
distributor to further optimize the propane. an rv grind cam would be about the highest lift and duration i'd go ( from talking to other guys with more experience with
propane only ). they told me
propane doesn't like a lot of cam. hope this helps...
