Gas gauge reading correctly??
Not to long ago I replaced the fuel sender in my 79 sb. I bought it from Advanced Auto and did not look like the original. The float is a plastic square box compared to the round float that it did have. Well anyway I filled up today and it onlt took 10 gal. and my gauge was just above "E". That doesn't sound right does it??? The tank is new and is mounted behind the axel.
I did the same thing w/ the same sending unit from Advanced about a month ago and mine does the same thing. I'll fill up and drive about 20 miles and it was only reading about half a tank, meaning i used about 9.5 gallons of fuel. Wrong, it only took 2 gallons to fill up. I wasn't sure if mine was attributed to the sending unit or crappy old gauge. I'm wishing I had replaced it with a sending unit w/ the original type of float. Glad you asked the question because I thought I was the only one.
jb
jb
Then,
__it may be not getting full contact to stud terminals & causing flux/inaccurate readings.
Plus, some sending units don't have the same size threaded terminal studs.
(There usally smaller.)
P.S. don't forget to check your grounds at your Gage Cluster.
Plus put a ground to the chassie from the battery.
This should help.
This should help.
Buzzerd,
__just in case you are not at the other page. https://www.ford-trucks.com/forums/7...uel-gauge.html
Here.
There,
__was no manufactured chassie ground.
You have to put one in. Two ways of doing this.
1. run batt.cable (no smaller than 6-ga.) from ground on battery to a bare metal spot on chassie, use a spiked washer (makes a more correct contact.) inbetween cable & chassie. Don't forget to put DIELECTRIC sillcone grease on the parts & chassie. (This grease is the same stuff you put in your spark-plug boots.)
2. run ground from engine block to chassie. Don't forget your spiked washers & D-grease.
TIP: your original ground should be going from your battery to your Engine block,
Directly to your block.
NOT to a bracket, intake bolt/nut, exsast manifold nut/bolt, Or even to the engine head.
Only, Directly to your block.
This the one & best soild route to grounding the block.
I have no less than 3 grounds on my own trucks & cars. (one to engine, one to chassie, & one to the body.)
Here.
There,
petermck
11-21-2016 06:33 PM
LvBohemian
10-29-2014 10:51 AM
gissmo2
03-18-2014 07:34 PM
fmc400
02-19-2013 12:09 PM
