2002 Explorer OD Light flashes - Ford Truck Enthusiasts Forums
Old 12-04-2008, 12:56 PM
jeepnutz jeepnutz is offline
jeepnutz is starting off with a positive reputation.
I have a 2002 Ford Explorer and the OD light flashes off and on at periodic times, doesn’t matter if I depress the button on the shift lever or not....any ideas why/what this can be?
thanks,
Dave
Old 12-04-2008, 11:16 PM
ricbro ricbro is offline
ricbro is starting off with a positive reputation.
O/D OFF light
I have a 99 windstar that flashs the O/D OFF light on the instrument panel. Seems to do it after it has been driven 25 kms or more. Might be temp dependent.Doesn't seem to affect the way it drives and goes away each time it sits over night. Don't know what causes it.
Old 12-05-2008, 09:03 AM
Sounds like it could be the same problem...... dosen't flash untill it's been driven for a few then the flashing starts. I'm trying to sell the car so it would be nice if I could get it to stop?
Old 12-05-2008, 10:15 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
There are about 50 things that can go wrong in the trans and make the OD light flash. The flashing light means there is a problem with the trans system and a code to explain the problem has been stored in the computer's memory. You MUST have the codes read to fix the problem. The places that advertise that they read codes free don't have the right tools to read Ford trans codes. You'll need a good independant shop or a Ford dealer.
Old 12-05-2008, 11:54 AM
Thanks Mark for the feedback. I'll get it into a shop and go from there.
Thanks again,
Dave
OD light flashing? Gwilkrrs Explorer, Sport Trac, Mountaineer & Aviator 2 04-20-2016 07:51 AM
2002 ford explorer clunk Primerranger Explorer, Sport Trac, Mountaineer & Aviator 8 03-12-2015 07:11 PM
overdrive off light flashing tomo805 Explorer, Sport Trac, Mountaineer & Aviator 1 11-20-2011 09:15 AM
flashing od light bradman755 Clutch, Transmission, Differential, Axle & Transfer Case 3 03-02-2007 01:47 PM
2002 Explorer - Strange stumble/miss/lurch tvulcan Explorer, Sport Trac, Mountaineer & Aviator 4 10-28-2006 09:10 PM
Tags
2002, blinks, ecplorer, explorer, flashes, flashing, ford, forum, instrument, light, od
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
