ridiculous wheel hop - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-04-2008, 12:01 PM
BigJake34452 BigJake34452 is offline
BigJake34452 is starting off with a positive reputation.
my 00 f250 super cab long bed 2wd is a great truck. but where i live there are alot of dirt roads, but i still dont need 4wd. anyway whenever i get to some sugar sand, no matter how much or how little i step on the throttle, it hops like crazy. it is the most aggravating thing about the truck. any idea on how to stop this?
Old 12-04-2008, 12:06 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Quote:
I had the same problem when at the beach in the 2wd F-250 I had. Trying to drive in the sand was so aggravating. The only way I found to stop this was to buy me the truck I have now. That is extreme, but it stoped the hopping.
I don't know how to stop the hopping.
Old 12-04-2008, 12:09 PM
UP_There's Avatar
UP_There UP_There is offline
UP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud of
I'm not familiar with the 2wd setup. Are there blocks on the rear axle? Lift blocks are the main reason for wheel hop or otherwise known as "axle wrap" on a 4wd. I cured mine by a new lift that is all spring, no blocks
Old 12-04-2008, 12:33 PM
Bigfwt04's Avatar
Bigfwt04 Bigfwt04 is offline
Bigfwt04 has a good reputation on FTE.Bigfwt04 has a good reputation on FTE.Bigfwt04 has a good reputation on FTE.
Try these, I am thinking about them too.
Traction Bars - Tuff Country EZ-Ride
Old 12-04-2008, 12:35 PM
naa, no blocks in it. all stock, it is just annoying because my 76 f250 long bed does just fine. everytime it gets to hopping i am just waiting for the u-joint to go bye bye.
Old 12-04-2008, 01:09 PM
whats the difference in the rear of a 2wd from a 4wd? says its for 4x4's only.
Old 12-04-2008, 01:13 PM
UP_There's Avatar
I've never even looked under a 2wd Superduty, but I do know the frontend is completely different. Does your rear-end have limited slip? That might cause the hopping in loose sand if you don't have it......I'm just throwing ideas out now
Old 12-04-2008, 01:28 PM
I was going to meet my brother at the beach here, he was surf fishing. The sand was a little soft, but the other trucks made it fine, 1/2 ton trucks. I started down the beach, didn't get far. The truck was bouncing so bad I couldn't go anywhere. I had to back out and they came and picked me up. I think the front of these trucks are so heavy that the front sinks and with no weight in the back, it just sits there and hops on the sand. My dually is much better in the sand. If I had 4x4 on the F-250, I don't think I would have had that problem.
Old 12-04-2008, 01:33 PM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.
Are you sure about that? I thought the 250's had 2 inch blocks and the 350's had 4 inch wether it was 2 or 4 wheel drive.
Old 12-04-2008, 01:39 PM
Bigfwt04's Avatar
Quote:
Air down your tires to 13-15psi, you will be amazed what a difference it will make. I can pull my 14000lb trailer out on the sand and over a hill no problem once aired down.
Old 12-04-2008, 01:41 PM
i looked, there is what looks like a 3/4 inch block. its not factory, but is that enough to make a difference? the truck is not limited slip, although 90% of the time when im going straight both spin, not it turns i dont think. maybe a leveling kit will help the weight balance a little.
Severe Axle Hop jgavac 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-19-2014 02:55 AM
Why does my SD hop and shake??? fordfarmer12 Modular V8 (4.6L, 5.4L) 6 11-09-2011 12:34 PM
tailgate hop. sawtooth 6.4L Power Stroke Diesel 14 12-20-2010 05:23 PM
How can I reduce wheel hop? Pitch Shims? mdjohnson 1987 - 1996 F150 & Larger F-Series Trucks 14 03-05-2006 02:01 AM
Wheel Hop On A Front Dana 44 TTB GHog Offroad & 4x4 17 08-14-2005 11:13 PM
Tags
05, 250, axle, f250, ford, frot, frtont, hop, power, pulls, sand, stop, stopping, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
