Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 12-03-2008, 11:29 PM
fordfan28 fordfan28 is offline
Garage is empty, add now
fordfan28 is starting off with a positive reputation.
Tire Replacement
I need some help to answer a friend's question. I'm more familiar with older fords, so I want to ask here to try to get the right answer for him.
His wife cut one tire on his 2008 Expedition. He replaced two tires rather than just the cut one. He was able to find the same make and model tire as he had on the vehicle. His other two tires are approximately 50% worn down.
Someone told him that he has to replace all 4 tires so they are all the exact same diameter or he will harm the 4x4 system.
I realize the newer vehicles monitor tire rotations for traction control, braking, etc.
Is this correct, that he should get all 4 tires or would it be within acceptable tollerance to run 2 old and 2 new tires with the same make and model?
Thanks in advance for any help.
  #2 (permalink)
Old 12-04-2008, 12:30 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
No, this is not correct. Unless the tires are near bald, you don't need to. Should all 4 tires have the same tread wear? Well in a perfect world when money is no object. She would have been fine with buying one tire, as I did. It won't harm anything.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 12-04-2008, 10:08 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
In all reality you should replace two (keep two new on the same axle) as you can throw the vehicle out of balance. You should actually look to make sure all 4 tires you put on a vehicle come from the same mold w/ the same date code. Take it from someone in the fleet business, replace all tires on the same axle.
Tags
2007, 2008, expedition, ford, harm, replacement, replacing, tire, tires, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
