how do i identify rear axle?
Old 02-08-2002, 09:07 PM
fortythree's Avatar
fortythree
fortythree is offline
okay, (forgive me, i'm new to this)
i have a 96 F250 reg cab 4x4 HD 351 5 speed ZF... i believe it has 3.55 gears (inside door says C9 which = 3.55)
tag on axle says: (i think, its kindof hard to read)
S 128 M
3L55 10 2 6C12
when looking at axle from under/behind truck, to the upper right and lower right of dif cover says "6065"... lower left says "A" (in a circle) and 10 - the "10" is big... upper left i cant make out...
when looking at the axle from under/middle of truck this is punched/embossed: E7TW-AA in lower right of dif...
inside door tag reads:
03/96 GVWR/PNBV: 8600LBS/3900KG
FRONT GAWR / REAR GAWR
PNBE AV PNBE AR
3559LB 6084LB
1614KG 2759KG
**********BUNCH OF TIRE JARGON*********
VIN: 2FTHF26H6TCA49291 |F0190
TYPE: TRUE / CAM |T1617
******************BARCODE******************
YO B6
EXT PAINT RC | D50
WB|BRK|INT TR|TP/PS|R|AXLE|TR|SPR
133 B 7V4 C9 W 64F
MADE IN CANADA CCT
thanks for any help, muchly appreciated
Old 02-08-2002, 10:55 PM
fortythree's Avatar
fortythree
oh ya, the reason i ask is because i want to buy this dana 60 front axle from a local auto wreckers (he says its out of a F350, i dunno which year yet, only talked on the phone - just in the first stages of finding a front axle) so i can get rid of my ttb ifs and install a solid front axle... i am hoping to buy this dana 60 (has 4.10 gears) and buy new 4.10 gears for my current rear end.. - i currently have 3.55 but when i throw on 35's i'll want lower gears anyways
but i am wondering if the dana 60 will be wider? like from wheel to wheel... i know i can cut off my lug bolts and buy spacers but i'd rather not...
if this dana 60 is out of a 92-96 F350, it should be the same width as my current axle right?
thanks a lot.
Old 02-08-2002, 11:20 PM
orange peel's Avatar
orange peel
orange peel is offline
it should be the same width, if its not it wont matter that much, old ch**ys used to have the front tires stickin out further than the rear cause of somethin with the 4wd.
Old 02-09-2002, 10:56 PM
Citoriplus's Avatar
Citoriplus
Citoriplus is offline
I don't know if anyone has told you but the tag on your rear end is the best chance of getting the right information on your axle. I just went through all this with my Ranger and went nuts trying to get a straight answer until I crawled under there with the local parts man from the Ford dealer and he told me what the numbers mean. On yours the top number is the lot (mfg.) number and means nothing to you unless there is a recall on that particular lot. The lower number is the important one for us and it says 3L55 10 2 6C12. Ok the first part says that you have a 3.55 ratio, The L says that there is a Traction-Loc carrier installed (limited slip) and the 10 2 says that you have a 10.25" ring gear. I'm sorry the 6C12 part wasn't part of my limited education. So I can't help with that part. I checked just for fun and there is a 4.10 ring and pinion set available for it.
Good Luck
Old 02-27-2002, 10:00 PM
my74f250's Avatar
my74f250
my74f250 is offline
Hi, This may sound really dumb but I need help Identifying both my front and rear axle!! If anyone could give me some help i'd appriciete it!!
I'm not totally sure but I think that I have a Dana 44 6cf-hd int the front and a Dana 60 or 61 in the back with a 4.10!! If there is any way you could help me confirm this that would be great!!
Old 02-27-2002, 11:15 PM
79F2504x4's Avatar
79F2504x4
79F2504x4 is offline
I am guessing your talking about the 74 in your name. Check the tagson the diff cover, someone here can read them for you. If the tags arent there, there should be numbers cast into the diff housings in the area where your axle tubes connect.
Chase
1979 F-250 4x4
71 460 Holley650, MSD OFFROAD, L&L Headers
C6-B&M Transpack
Dana HD44Front/60Rear
35 inch Goodyear Implement Tires
4 inch Skyjacker System
Much more to come
Old 02-28-2002, 06:21 AM
72f100's Avatar
72f100
72f100 is offline
Old 02-01-2013, 08:20 PM
fordfanatic54's Avatar
fordfanatic54
fordfanatic54 is offline
i need help
i have a 77 f250 3/4 ton and i need to figure out what rear end i have in it. i know its not the original rear end i think it has 1 ton running gear in the rear. i can upload pictures if needed... thanks
popsicleped
1997 - 2003 F150
07-09-2017 11:24 PM
abosely
03-27-2016 05:37 PM
mzogs
30
12-28-2015 12:31 PM
mzogs
12-15-2015 11:58 PM
bryan_johnson
11-04-2007 05:44 PM
Quick Reply: how do i identify rear axle?
