how do i identify rear axle? - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Old 02-08-2002, 10:07 PM
fortythree fortythree is offline
fortythree is starting off with a positive reputation.
okay, (forgive me, i'm new to this)
i have a 96 F250 reg cab 4x4 HD 351 5 speed ZF... i believe it has 3.55 gears (inside door says C9 which = 3.55)
tag on axle says: (i think, its kindof hard to read)
S 128 M
3L55 10 2 6C12
when looking at axle from under/behind truck, to the upper right and lower right of dif cover says "6065"... lower left says "A" (in a circle) and 10 - the "10" is big... upper left i cant make out...
when looking at the axle from under/middle of truck this is punched/embossed: E7TW-AA in lower right of dif...
inside door tag reads:
03/96 GVWR/PNBV: 8600LBS/3900KG
FRONT GAWR / REAR GAWR
PNBE AV PNBE AR
3559LB 6084LB
1614KG 2759KG
**********BUNCH OF TIRE JARGON*********
VIN: 2FTHF26H6TCA49291 |F0190
TYPE: TRUE / CAM |T1617
******************BARCODE******************
YO B6
EXT PAINT RC | D50
WB|BRK|INT TR|TP/PS|R|AXLE|TR|SPR
133 B 7V4 C9 W 64F
MADE IN CANADA CCT
thanks for any help, muchly appreciated
Old 02-08-2002, 11:55 PM
oh ya, the reason i ask is because i want to buy this dana 60 front axle from a local auto wreckers (he says its out of a F350, i dunno which year yet, only talked on the phone - just in the first stages of finding a front axle) so i can get rid of my ttb ifs and install a solid front axle... i am hoping to buy this dana 60 (has 4.10 gears) and buy new 4.10 gears for my current rear end.. - i currently have 3.55 but when i throw on 35's i'll want lower gears anyways
but i am wondering if the dana 60 will be wider? like from wheel to wheel... i know i can cut off my lug bolts and buy spacers but i'd rather not...
if this dana 60 is out of a 92-96 F350, it should be the same width as my current axle right?
thanks a lot.
Old 02-09-2002, 12:20 AM
orange peel orange peel is offline
orange peel is starting off with a positive reputation.
it should be the same width, if its not it wont matter that much, old ch**ys used to have the front tires stickin out further than the rear cause of somethin with the 4wd.
Old 02-09-2002, 11:56 PM
Citoriplus Citoriplus is offline
Citoriplus is starting off with a positive reputation.
I don't know if anyone has told you but the tag on your rear end is the best chance of getting the right information on your axle. I just went through all this with my Ranger and went nuts trying to get a straight answer until I crawled under there with the local parts man from the Ford dealer and he told me what the numbers mean. On yours the top number is the lot (mfg.) number and means nothing to you unless there is a recall on that particular lot. The lower number is the important one for us and it says 3L55 10 2 6C12. Ok the first part says that you have a 3.55 ratio, The L says that there is a Traction-Loc carrier installed (limited slip) and the 10 2 says that you have a 10.25" ring gear. I'm sorry the 6C12 part wasn't part of my limited education. So I can't help with that part. I checked just for fun and there is a 4.10 ring and pinion set available for it.
Good Luck
Old 02-27-2002, 11:00 PM
my74f250 my74f250 is offline
my74f250 is starting off with a positive reputation.
Hi, This may sound really dumb but I need help Identifying both my front and rear axle!! If anyone could give me some help i'd appriciete it!!
I'm not totally sure but I think that I have a Dana 44 6cf-hd int the front and a Dana 60 or 61 in the back with a 4.10!! If there is any way you could help me confirm this that would be great!!
Old 02-28-2002, 12:15 AM
79F2504x4 79F2504x4 is offline
79F2504x4 is starting off with a positive reputation.
I am guessing your talking about the 74 in your name. Check the tagson the diff cover, someone here can read them for you. If the tags arent there, there should be numbers cast into the diff housings in the area where your axle tubes connect.
Chase
1979 F-250 4x4
71 460 Holley650, MSD OFFROAD, L&L Headers
C6-B&M Transpack
Dana HD44Front/60Rear
35 inch Goodyear Implement Tires
4 inch Skyjacker System
Much more to come
Old 02-28-2002, 07:21 AM
72f100 72f100 is offline
72f100 is starting off with a positive reputation.
Old 02-01-2013, 09:20 PM
fordfanatic54 fordfanatic54 is offline
fordfanatic54 is starting off with a positive reputation.
i need help
i have a 77 f250 3/4 ton and i need to figure out what rear end i have in it. i know its not the original rear end i think it has 1 ton running gear in the rear. i can upload pictures if needed... thanks
buying a f-350 I-6 300 mzogs 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 30 12-28-2015 01:31 PM
Thinking of buying a 86 f-350 with 300 I-6, looking for specs. mzogs 1987 - 1996 F150 & Larger F-Series Trucks 9 12-16-2015 12:58 AM
Need help decoding door jamb sticker (noob) nezwick 1987 - 1996 F150 & Larger F-Series Trucks 12 12-24-2014 10:12 PM
figuring out my tow weight PEI 1999 - 2003 7.3L Power Stroke Diesel 18 04-28-2012 12:34 PM
Axle identification. 88mmFlaK 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 05-23-2007 01:23 PM
Tags
1025, 60, aa, axle, dana, e7tw, e7twaa, end, front, gawr, identify, identifying, rangers, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
