Help! ticking noise from dash?
Old 03-07-2000, 01:38 PM
Chris Bergman
Guest
Posts: n/a
I have a '97 F150 that has developed a ticking sound coming from either the dash around the gauge cluster or the steering column. The sound is intermittent right now, but seems to be getting worse and more regular. The sound only seems to occur under 35 mph. I have pulled the dash apart, but could not locate the problem. I suspect that the problem could be related to something electrical, which concerns me. I have seen this problem posted on other web sites before, but no solution.
I would appreciate any comments or solutions to this problem. Any help would be greatly appreciated.
Thanks
Old 03-21-2000, 12:56 PM
JohnF's Avatar
JohnF
JohnF is offline
MAYBE ITS THE SPEEEDOMETER CABLE, MY TRUCK DID THE SAME THING, I GOT A BOTTLE OF GRAPHITE AND POUR SOME ON THE CABLE, YOU HAVE TO USE DRY LUBRICATION.
Old 03-21-2000, 11:39 PM
Torky's Avatar
Torky
Torky is offline
Sorry, don't have any ideas what it could be, but its not a speedo cable. These trucks speedo is all electric, no wire in a core type mechanical cable anymore.
Old 03-23-2000, 10:22 AM
JMC's Avatar
JMC
JMC is offline
You have to pull the instrument cluster out to get at it. My 97 did the same thing and the odometer stopped working. The gears inside get stuck. Spray some lube on the gears to the odo and it should take care of it.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back
Modified Air Cleaner Outlet Tube
and air box, K&N air filter,
Superchips
Old 05-09-2000, 08:57 PM
nateyc's Avatar
nateyc
nateyc is offline
This noise is from the airbag on the passenger side.
Have Ford remove the bag and inspect. One of the wiring harness was loose as well as one of the hold down bolt assembly.
Old 05-09-2000, 11:13 PM
big dude's Avatar
big dude
big dude is offline
TrukProblemz
2004 - 2008 F150
02-10-2014 02:51 PM
singr_69
1997-2006 Expedition & Navigator
19
12-20-2010 05:06 PM
west tn 6.0 powerstroke
1999 to 2016 Super Duty
10-26-2009 10:19 PM
stevieray
21
03-17-2005 10:51 PM
Red_EB_Bronco
04-26-2003 12:31 AM
Quick Reply: Help! ticking noise from dash?
