Polarizing voltage regulator - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 01-09-2013, 08:53 PM
prestondave prestondave is offline
prestondave is starting off with a positive reputation.
Thanks for the information! My "new" 1963 f100 has been sitting since 1997. It has a "New" generator and regulator installed in 1997. I'm hoping this procedure will get the generator charging again. Then on to the next outdoor, Northwest storage induced problem corrected...
  #32
Old 05-24-2014, 09:53 PM
Steve51's Avatar
Steve51 Steve51 is offline
Steve51 is starting off with a positive reputation.
Just installed a new battery on my 51 F-1 and found I had lost charging from the generator. Found this post and disconnected the Field wire and touched it to the Battery wire. I observed the small blue spark, reconnected the field wire to the regulator. On starting up, the charge gauge shows charge again. Thanks for the excellent help!
Steve51
installed battery backwards Vernon Myers 1968-2013 Full Size Vans 3 02-21-2016 06:28 PM
Generator issues.. fifty-two_f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 08-20-2014 12:14 PM
1979 F600 Voltage Regulator Issues daltonhawk Electrical Systems/Wiring 4 12-21-2011 02:08 AM
Polarizing voltage regulator on 1967 F-100 AWBraschler 1967 - 1972 F-100 & Larger F-Series Trucks 4 05-21-2010 12:34 PM
1950 Generator advice 1950ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-28-2007 02:00 AM
Tags
1949, 1967, adjust, dash, f1, f100, ford, polarization, polarizing, regulator, relay, sportster, starter, volt, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
