Today i was told i could put f350 springs on the front of my f150. and this would raise it up about 2 inches giving me enough clearance for new, bigger tires. is it true?
Well first off, your 150 is a coil sprung unit and the 350's are leaf sprung...so it would be a tad bit more difficult than a bolt on application.
And I believe it would be more like 4"...if all you want is 2 more inches (which every guy wants, right?) just get some AAL's...they'll stiffen up the ride a little, but it'll net you the 2" you want.
Coils from a 2wd F350 will fit under a 2wd F150. And yes its about a 2 inch lift, I did the swap on my 87 F150 2wd so I could fit 33's under the front. The ride was really rough, but I imigine it would soften out if you ever got a big bumper for the front.
front 2wd f350 springs will also fit a f150 4x4. I don't think this raises the front end any higher than it was originally...but it may raise it several inches higher that it is currently if they are now weak. I did this on my 93 4x4 so it could handle the plow. I used the regular duty f350 springs...in hindsight, I wish I had gone with the Heavy duty for the plowing. Good cheap solution.
pretty much...im gonna say if you find a pair of coils that are the same diameter it souldnt really matter what truck they are out of and if the springs are 2 inches taller guess what...
so just to summerize this. I can get f350 2wd springs to put in the front of my 2wd f150...
correct?
Correct. I'm actully wondering if the f350 springs are any taller or if they're just so much stiffer that they don't squat when they're under an f150...?...
