Caliper Bracket Bolt fo 2001 Expy
Advance Auto steered me toward the hardware store (?)
isn't it something one can buy at an auto parts store?
yeah they say it's "case hardened."
You know, I don't know. I did my own brakes, had to take the brackets off to smack the bejeezus out of the rotors to get them off. I put everything back together, and I cranked like hell to make sure they were back together. I had to use some pretty extreme heat to get everything off, including these bolts, but I don't think that would have compromised them. It was about 17 degrees when i put the bolt back in, it's since changed from that to 70+ degrees, back down to near zero, and up to 30 degrees. maybe the change in temp?
The best you could probably do is take the other one out, and head to a hardware store and see if they have something that would fix you up. Make sure you get the threads right, and the length to. A lot of specialty bolts like that you're not going to find in the bolt bins at a hardware store, but you might get lucky. You'll have better luck if you go to a mom and pop type store (or maybe an ace, I usually have good luck there) than if you try to go to a big box like home depot or something.
And do yourself and everyone else a favor and don't skimp on it. Get a grade-8 bolt, even if it's expensive.
I needed one for a friends Explorer and we took one to the hardware store to match up and had no problems finding one the same hardness. It will be metric and will us a designation like 8.8 stamped on the head to denote the hardness. I would use loctite red (removable) when reinstalling the bolts as you will notice there is a thread locking coating on the original bolts.
DEMIGOD
1997-2006 Expedition & Navigator
04-18-2015 11:01 AM
galeo68
07-20-2010 08:03 AM
CobraGT40
03-19-2010 07:24 PM
