68-76 F250 4x4 c6 tail shaft - Ford Truck Enthusiasts Forums
Old 12-01-2008, 04:21 PM
tex4431 tex4431 is offline
tex4431 is starting off with a positive reputation.
I was wondering if the tailshaft of a fixed yoke 2WD C6 transmission is the same a (Highboy)F250 4x4 C6 transmission?
Old 12-01-2008, 06:09 PM
tatonka04's Avatar
tatonka04 tatonka04 is offline
tatonka04 is starting off with a positive reputation.
This is weird, because I too have the same problem. I just busted the tranny case in my 75 F250 4x (the one in my sig), today and was fixing to research it.
So can anybody clarify what I might be able to use for a tranny? Do I need to look for a 2wd tranny and swap tailshaft assemblies or get a 4wd tranny and add my tailshaft assembly?
PS, Thanks Tex for bringing it up!
Old 12-01-2008, 06:29 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
You can use a 2wd tranny, but the tailshaft won't have the mounting hole setup for the 4x4 shifter. I've seen where guys have just used the 2wd tranny along with it's 2wd tailshaft and just make a bracket for the shifter. You'd have to get a short driveshaft with a slipyoke made. If you can find a 4x4 tailshaft, you should be able to swap them out and go from there.
tatonka04's Avatar
Yeah, I know about the differences according to which motor you have, (351m/400,460, or 302,300, or FE, but since my high boy tranny is similiar to a 2wd tranny, except for the shifter on the side, I thought that it might just be a tailshaft swap thing if I find one. Or, do I look for a 4wd tranny like the married 4wd trucks use, and put my tailshaft on?
Old 12-01-2008, 06:32 PM
tatonka04's Avatar
Sorry Buck, I guess I was typing. I'm wondering what the overall length difference is between the 2wd and the high boy tranny.
Old 12-01-2008, 06:35 PM
tatonka04's Avatar
This sounds like a job for NumberDummy!
Old 12-01-2008, 06:44 PM
I believe the 2wd tailshafts are longer, but the exact length I'm not sure.
Old 12-02-2008, 02:39 PM
So I was out working on the truck this morning and took a pic of my tailshaft.
Old 12-02-2008, 04:04 PM
tatonka04's Avatar
Thanks for the pic. I pm'd NumberDummy with the question and he was saying that a C6 housing is a .... so I guess I'll look for another housing and put my tail cone and shift linkage on it with or without having to change out output shafts. Looks like rebuild time!
David Nash 2 over / underdrive aux transmission? Dean06919 1987 - 1996 F150 & Larger F-Series Trucks 0 11-27-2016 11:27 AM
400 to 351W motor swap adamssho 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-28-2013 07:38 PM
c6 differencess snortonnorton 1973 - 1979 F-100 & Larger F-Series Trucks 9 02-28-2012 07:39 PM
1974 F100 -- Switch C6 TailShafts? skullmonkey17 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-09-2009 02:25 PM
C6 transmission kick down linkage deisele75 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-24-2006 07:32 PM
Tags
2wd, 4x4, 76, bracket, c6, f250, ford, highboy, housing, lengths, output, shaft, shafts, shifter, tail, tailshaft, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
