Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-30-2008, 05:51 PM
goda123 goda123 is offline
goda123 is starting off with a positive reputation.
what gears in your y block truck?
Just wanted to take a poll on what gears the y guys are running, & if your happy or disappointed with them.
  #2 (permalink)
Old 11-30-2008, 06:36 PM
flipklos flipklos is offline
flipklos is starting off with a positive reputation.
4.11 W t98 on a near stock 292.
Great acceleration, and effortless hauling/towing.
13mpg.........Iwant 3.73 or 3.89 gears the 1 or 2mpg would be worth it.
  #3 (permalink)
Old 11-30-2008, 07:58 PM
matt2491's Avatar
matt2491 matt2491 is offline
matt2491 is new and has a neutral reputation at this point.
My setup:
Stock 292 2bbl w/headers and Pertronix ignition.
4spd overdrive out of late 80's truck. Ratios are:
1st - 3.25
2nd - 1.92
3rd - 1.00
4th - .78
R - 3.25
Ford 9" limited slip rear end w/3.00 gears (swapped out original 3.89 gears)
Approximately 28" tall tires.
Overdrive is almost too much on the highway. It's like 16-1700rpm at 70mph. 3rd gear around town is awesome though - as long as you're not planning to get anywhere fast - motor RPMs just lug right along at a tad over 1000rpm, and I have noticed a substantial mileage increase.
  #4 (permalink)
Old 12-02-2008, 08:20 AM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 is starting off with a positive reputation.
I have one 56 with a 272 engine and a dana 44 with 2.72 gears. 20.5 mpg on the hway, but not very fun around town. I have to original rear with 3.92 gears, nice gears just not nice on the hway.
I have another 56 with a dana 44 with 4.27 gears, welded for a posi. 292 .060 over
Another is my 56 panel , it has y block with over drive and 3.92 gears. this is a nice set up.
Kevin Bigwin
__________________
1956 Custom Cab Big Window. 272 Y block 3sp. See gallery. Kevin
  #5 (permalink)
Old 12-02-2008, 10:03 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Ford 8 inch rear end with 3.00 gear. No overdrive.
__________________
1946 1/2 ton with Y-block
1964 F-250, 292 4 speeed
1990 Ranger 4WD
1954 Model 600 tractor
  #6 (permalink)
Old 12-02-2008, 06:31 PM
Sam_Fear's Avatar
Sam_Fear Sam_Fear is offline
<--It's a truck!
Sam_Fear has a good reputation on FTE. Sam_Fear has a good reputation on FTE.
I run a T-98 with 3.50 rear gears right now. Not quite right though. 2nd is a little too steep for take-off, and 1st is to short, so I have to shift too early - like half way through an intersection. But it's not too bad in 4th at 70 on the highway. Eventually I'm going to switch to a 3.00 or 3.25 (forgot which I decided).
__________________
I'm nothing more than words on your monitor.
  #7 (permalink)
Old 12-02-2008, 07:11 PM
46yblock's Avatar
Sam, someday I would like to switch my 3.00 for a 3.25, FYI.
__________________
1990 Ranger 4WD
  #8 (permalink)
Old 12-02-2008, 09:05 PM
matt2491's Avatar
Yeah I’m definitely planning to step it back down to maybe 3.50 someday. I’m being picky but I think that gearset coupled with the tranny gears, it’ll shift and cruise just right.
  #9 (permalink)
Old 12-03-2008, 04:41 PM
Sam_Fear's Avatar
<--It's a truck!
Quote:
46Y, what transmission do you have? If it's a T-98, how hard is it to get going?
I want to put some big tires on the rear and see what that gets me first. Right now (I think) I'm running 235/75R15's on the back.
__________________
  #10 (permalink)
Old 12-03-2008, 05:39 PM
46yblock's Avatar
Sam, I kind of dread that question, because the answer isnt too cool. It is a '46 three speed. Tires are close to 26 in. tall. Getting going isnt a problem, but the rear keeps the rpms down, probably too much so, unless you are going at least 55. Cant imagine Bigwin's 2.79.
__________________
1990 Ranger 4WD
  #11 (permalink)
Old 12-03-2008, 09:14 PM
Sorry for the long post in advance-
MY truck is a 63' with a 301, Isky E-4, 4v Eddlebrock, headers, ported heads, rebuilt stock Cruise O Matic.
Tires are 255/70R15's or 29.1" tall.
I have done three gear sceinerios with this truck.
I started with 3.73's in the stock dana 44 track lock.
Then Swaped in a 64' dana 60-2(5 lug dana 60) also track lock with 4.10's,
I Now just swapped in a 66' 9" with a pumkin from a mid 70's car with 3.00's & a factory ford track lock.
The 3.73's were good unless you went above 60 it started to feel like a waste of rpm on the highway. Difficult to pass above about 70, since it was hard to kick down above that.
The 4.10's were real fun around town, but sucked above 50! @ 75mph the engine was turning close to 4000! Red line with the Isky installed straight up with a stock chain is 5000! A joke to pass anyone unless you were going slow.
The 3.00's are pleasant so far, However I have only logged a few miles on it.
I am having some early shift issues, where even in town it is shifting way too early under light throttle.
Also if I slow down, but not below 10-15mph, it doesn't kick back down into 1st on it's ownunless I mash the throttle, or manually shift it.
I am kind of worried about this since the cruise o matic doesn't use a vaccum modulator like a FMX does.
I will Say that even though the higher ratio kills a little torque, the torque multiplication from the converter lets it take off nicely! An added bonus of high gears with an automatic & stock converter.
I'll adjust the linkage to stock specs & see what happenes.
Y-ask Y?
  #12 (permalink)
Old 12-06-2008, 12:37 PM
Sam_Fear's Avatar
<--It's a truck!
No matter what, it's still way cooler than a Saturn. Like my granny gear 4 speed is the king of cool. I don't wanna be a cool guy anyhow, those guys are annoying.
__________________
  #13 (permalink)
Old 12-06-2008, 02:57 PM
46yblock's Avatar
Quote:
What a hoot! Lots of chuckles .+
__________________
1990 Ranger 4WD
  #14 (permalink)
Old 12-07-2008, 10:38 PM
pintoplumber pintoplumber is offline
pintoplumber is starting off with a positive reputation.
Dana 44 3.92 borg warner overdrive. Love it for around town and out on the highway.
Would love to have the 4.27 for racing like Kevin. Dennis in PA
  #15 (permalink)
Old 12-11-2008, 09:17 PM
matt2491's Avatar
Hey pintoplumber, whats the overdrive gear ratio?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
