DIY - Cam Phaser Replacement - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 04-10-2012, 12:13 AM
cpogjl cpogjl is offline
cpogjl is starting off with a positive reputation.
Steve, I hope you're still reading this email. This is an excellent explanation of how to remove and replace a phaser. In my research to figure out the fix for my 2005 f150 I came upon this forum post P0345 Runs Bad! - Ford F150 Forum I'm curious if you have seen his post, and what your thoughts are on realigning the cam/phaser prior to purchasing a replacement phaser.
  #32
Old 04-10-2012, 07:47 PM
PeterTheWolf PeterTheWolf is offline
PeterTheWolf is starting off with a positive reputation.
Quote:
Originally Posted by IA_Chiefs_fan View Post
You can rent of buy the FR-303-1175-TD timing chain wedge here Timing Chain Locking Wedge
IA_Chiefs_Fan,
Can you please post the dimensions you used for the tool you made?
Thanks..............
  #33
Old 04-10-2012, 08:16 PM
IA_Chiefs_fan IA_Chiefs_fan is offline
IA_Chiefs_fan is starting off with a positive reputation.
Quote:
Originally Posted by PeterTheWolf View Post
IA_Chiefs_Fan,
Wouldn't recommend trying to make a homemade one. Too many horror stories. Rent or buy one here and be safe Timing Chain Locking Wedge FR-303-1175-TD
  #34
Old 05-29-2012, 08:00 PM
atikovi atikovi is offline
atikovi is starting off with a positive reputation.
Does the 4.6L engine have cam phasers too?
  #35
Old 11-28-2012, 11:29 AM
FX2nut's Avatar
FX2nut FX2nut is offline
FX2nut is starting off with a positive reputation.
All parts and tools are ordered, hopefully i'm able to complete it this weekend
  #36
Old 11-28-2012, 12:19 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
FX, I'd say welcome to FTE, but even though this is your first post, I see you've been lurking for over 4 years!
Nice to see ya get in the lime light and outta the shadows!
Stewart
  #37
Old 11-30-2012, 02:38 PM
FX2nut's Avatar
Thanks, I'm always on but don't post much. I'm more active on FordF150.net. Everything is supposed to be here today and going to get started tomm afternoon
  #38
Old 11-30-2012, 04:57 PM
Stewart_H's Avatar
Well I hope we see you posting more often here. Good tech is always welcome!
Stewart
  #39
Old 12-03-2012, 10:16 AM
FX2nut's Avatar
Is there any good way to rotate the engine to verify I have it in time. According to my haynes manual. there should be 2 colored links that should line up with the arrow on the phaser. I want to make sure before starting so i know if it is in time. Don't want to take the chance of something not being right
  #40
Old 12-03-2012, 11:27 AM
Steve_Uzi Steve_Uzi is offline
Steve_Uzi is starting off with a positive reputation.
Not really... Unfortunately due to different size gears (Phazer gears are almost 2x the crank gear). You will Never get the links to line up to the marks on the phasers / crank gear.
You can rotate the engine around until you have a colored link CLOSE to the mark on the phasers or crank gear. What you can do is simply count the offset of the colored links to the marks and that should be consistent across all 3 gears..
Example - the colored link on Passenger phaser link is 5 "Teeth" off. Well then so should the Drivers side (obviously in the same direction) as well as the Crank.
Honestly if you engine was a link or two off - you would know it!
Also - invest in the FORD Manual - I have mine for sale! It is a 2006 F-150 Manual - Cheap! $80 Shipped!
Good Luck - Also if you do a search - I recall someone posting the pictures (Maybe even Me! haha) about the gears.
-Uzi
  #41
Old 04-25-2013, 10:20 AM
horn4life horn4life is offline
horn4life is starting off with a positive reputation.
Tool and part questions
First off here is a link to exactly what my Expedition sounds like I got from the other forum
Loud ticking at 35 seconds is my biggest concern. It the phaser about to blow up? Or timing chain now getting loose and "slapping" causing the harder ticking?
I screwed up and put in too heavy oil before a trip and the damage was done but I have been too busy remodeling the house to make the work priority one. Now my truck sounds like the video and I need to get after it. I am assuming for parts both phasers, and perhaps timing belt tensioners (do I have to remove timing cover to gain access?) maybe all the lifters? Or at least pull and inspect?
Anyhow wondering what you guys think after listening to the other guys video.
ALSO here is a time lapse Cam Phaser Change that is a great example done by a professional, looks like he has a special valve tool to inspect/replace cam followers?
Trying to order all the parts today and afraid to drive the truck until I do the work (unless I am more afraid than I should be) as cheaper parts are a day or two away.
Thanks in advance from Austin Texas
  #42
Old 06-20-2013, 10:15 AM
Mitch Court Mitch Court is offline
Mitch Court is starting off with a positive reputation.
Steve, thanks for posting this with the photos, I'm going to work on replacing both sides this weekend. I'm still nervous about the wedge placement,but ill figure it out. Should I replace the timing chain already at 130K? The phaser knock is somming from the passengers side only.
  #43
Old 02-11-2014, 11:09 PM
Reidtriton Reidtriton is offline
Reidtriton is starting off with a positive reputation.
Cam phaser problem?
Hi there, Im new to the Thread but do have some knowledge about this topic because i've read almost every single one. My truck has had a ticking noise for almost 150,000 km. in the last 5000 km it has gotten worse and worse not it has almost a knock at operating temp and no longer a tick. I have seen no CEL or effect in power or idle condition. should i be worried or even just do the phaser my self? I have a video of the motor that i will post.
  #44
Old 02-15-2014, 04:13 PM
Island Truck Island Truck is offline
Island Truck is starting off with a positive reputation.
Cam Phasers
I changed my phasers generally following Steve's excellent post. I also bought the ford manual from Ebay and that had some good tips too.
As far as "should I replace my timing chain at only 130k" question, I would say that it's not a question of mileage, but a question of how close you are to having access to it. Once you've got the valve covers off, you've really done the hard part in my opinion. Might as well go the extra mile and do the chains seeing as you're so close.
Not to mention that the chain tensioners and guides often have issues at about your mileage.
I did just the phasers the first time and was stoked at how much better it was. For a month. Then I had to take the whole thing apart again and do the chain and chain tensioners and guides. (my guides were fine, the tensioners were shot).
So that's my advice... go for it and just do this job once.
  #45
Old 04-04-2014, 09:27 PM
cbharis cbharis is offline
cbharis is starting off with a positive reputation.
Steve,
Thanks for the post. Is it a possibility to get the pictures re-posted as they are not working for me anymore? Many thanks in advance!!!
2007 5.4L phaser lockouts installed. JP3 2004 - 2008 F150 11 03-27-2017 07:32 AM
How to Save Installing 18 of 24 Followers on a Timing Job. macubus 2004 - 2008 F150 7 03-20-2017 09:40 PM
Cam Phaser / Timing Component Replacement Help Needed jrroth 2004 - 2008 F150 6 09-17-2013 05:44 PM
Tags
2005, cam, chain, expedition, ford, kit, noise, phaser, phasers, replacement, solenoid, timing, tools, vct, wedge
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
