96 250 radiator support bracket removal
my 96 f 250 needs a new radiator support bracket cause its really rotted.can i take it off in sections?like does the top bar that goes across the top of the support from one end of the engine to another unbolt from the bottom of the support? it looks like it may but im not sure?or do i have to take it all out in one piece?im trying to make it easy on myself.also how do i go about putting the new radiator support back in?thanks for the info!
on
The rad support is 1 piece.. at least a new one is anyway.. so you're gonna have to take it all apart anyway. The rad support is attached to everything so you really have to strip the front of the truck to change it. That means the grill and all lights, bumper and trim, then you remove the washer/coolant containers and battery and tray, and then disconnect the rad from support but you don't have to remove the hoses or drain it. Now you can remove all the screws attaching the rad support to the fenders and chassis and pull it out.
bringin back an older thread...
i have a 96 F350 with a 351 that needs a new support. i'm hoping to find a good used original one. what donor trucks would work for me? i'd imagine it would have to be a 93-96/97 f series or bronco? is that true? does it matter what engine the donor truck has in it? thanks.
so i've been looking the last couple of weeks for a good used support, but most around here (in CT) are in rough shape. i was hoping for an original, but i think i may have to start looking at aftermarket pieces. are all created equal? i don't want to buy one made with, cheap, thin metal, but i don't want to spend a fortune on one either...
who sells the best support?
I found 3 sources for 92-96 radiator supports:
eBay – $109 + $89 shipping
AutoKrafters - $180 + $100 shipping
LMC Truck - $190 + $48 shipping
So of these 3, I’ll go with LMC Truck. Before I order, anyone else have any opinions of these 3 suppliers? Any other suppliers I should be considering?
And I called my local carquest as suggested, but they didn't have a listing. If there a carquest part number you know of?
richlars
07-16-2014 05:13 PM
stroker393
04-11-2013 06:09 PM
jtharvey
20
03-14-2008 08:39 AM
