opinions on removing marker on junk yard find - Ford Truck Enthusiasts Forums
Old 11-29-2008, 06:20 PM
X36 X36 is offline
X36 is starting off with a positive reputation.
Hi all.I figured I'd try here before the the autobody section whichs kinda sloooow.I found a real nice hood at a local yard which happens to be the same color as my truck .The problem is that when the junk yard inventoried the trk they wrote 3 times on the hood inv #'s and "Motor Good".In that heavy yll marker they use.Any ideas on getting it off Hoods blue).Without ruining the paint.The #'s and letters will likely ghost into the paint or not ???
Thanks
Old 11-29-2008, 06:30 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Lighter fluid
Old 11-29-2008, 08:18 PM
DPorter DPorter is offline
DPorter is gaining momentum as a positive member of FTE.
oven cleaner. Used this to remove hand painted lettering off my trucks. No harm to the original paint.
Old 11-29-2008, 10:41 PM
Bullitt390's Avatar
Quote:
No friggin' way anyone should use Oven Cleaner to remove a marker on paint! You can use Easy Off oven cleaner to remove the ANODIZING on the grille shell, but not on Paint!
Lighter fluid, nuff said.
Josh
Old 11-29-2008, 10:50 PM
Bullitt390 when did you use oven cleaner to remove anything?
Easy Off oven cleaner to remove acrylic paint on lettering works very well and did NO damage to the finish.
Know what you speak of before being so certain.
This trick was given to me by the sign painter. Very effective.
It took about one hour to clean both sides of the truck, doors and box.
Now I don't know if it would remove the marker used here but it can not hurt to try.
Old 11-30-2008, 12:37 AM
Bgasrickshaw Bgasrickshaw is offline
Bgasrickshaw is starting off with a positive reputation.
I always use Easy Off oven cleaner to degrease engines and other greasy parts, (way cheaper than "Gunk",) so I just assumed it would eat paint ( it does sometimes take paint off the valve covers, etc, but maybe that's because it's old, oil impregnated paint?) I never actually tried putting it on a paint job
Old 11-30-2008, 02:59 AM
dakonthemountain dakonthemountain is offline
dakonthemountain is starting off with a positive reputation.
How about WD40?.. It seems to clean everything!
Old 11-30-2008, 08:46 AM
armstrongfordtrucks armstrongfordtrucks is offline
armstrongfordtrucks is gaining momentum as a positive member of FTE.
I usually use lacquer thinner for cleaning everything off the old paint. When my truck was shipped in from S.D. the paint was ugly, tried everything to clean it with no luck, then used lacquer thinner,washed it with hot soapy water, then mothers clay bar, good coat of wax and it looks great for 33 year old paint. It will remove some of the paint.
Old 11-30-2008, 02:15 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud of
Get some compoud adn a buffer wound be the best way. And when i mean a buffer im not talkin that trash from walmart that orbits. Im talkin a good buffer that looks like a 7" grinder. Plus do the whole hood and itll bring back the luster of the paint. How do i know this? 1 st place in county and state autobody collision repair and 18th out of 100 in the nation in 2005.
Old 11-30-2008, 02:31 PM
X36 X36 is offline
Thanks for all the great help.I thought I might be screwed,BUT now I think I can turn it around
Regards X36
Old 11-30-2008, 07:25 PM
masterbeavis's Avatar
masterbeavis masterbeavis is offline
masterbeavis has a very good reputation on FTE.masterbeavis has a very good reputation on FTE.masterbeavis has a very good reputation on FTE.
I am not a paint and body guy, but I do know a few things about removing stuff that doesn't belong from surfaces that need to be preserved. I am a firm believer in starting with the least obtrusive method and work my way up to the nasty stuff. Laquer thinner is the last resort on the list of things I use that works. I wash first, then commercial degreaser, "Awesome", "Simple Green", "Goof Off NUMBER TWO" (water based), grafiti remover etc etc. Next is buffing compound with a clean soft cloth. IF I use lacquer thinner, I make sure to never linger with it, nor scrub too much. It will soften your paint, and if you disturb it while its softened, you will remove it. I like the 7" buffer for large buffing jobs of heavily messed up paint jobs, however I do not like the swirl marks that it leaves. The chances of ruining a paint job by an un-trained novice is very good. The POS 5" buffers you buy from Wal-mart are slow, and suck, but with patience and the right technique, they do get the job done, without swirl marks.
Edit, you would be AMAZED at what Mr. Clean "magic" sponges will clean(especially inside the house). It is important to test them on an inconspicuous surface first, they will dull some finishes. I use the sponge to avoid 80% of the paint touch up I normally would have to do inside of a house.
Old 11-30-2008, 07:48 PM
OrangeJuice OrangeJuice is offline
OrangeJuice is gaining momentum as a positive member of FTE.
I would try some mineral spirits. It works good at removing gunk on the paint without harming it. If that doesn't work try some Dissolve It cleaner.
Old 11-30-2008, 09:37 PM
Quote:
True i never took that into consideration. Not hard to burn through paint if your not careful.
Old 11-30-2008, 09:47 PM
1968customcab's Avatar
1968customcab 1968customcab is offline
1968customcab is starting off with a positive reputation.
On a hood that has been sitting out in the sun and is that old, you are most likely gonna remove some clear(if any still exists) or some paint. But goo gone and cleaner wax work very well at removing all kinds of markings and normally will not damage the paint. Just my 2 cents.
Old 11-30-2008, 09:50 PM
fordnut forever's Avatar
fordnut forever fordnut forever is offline
fordnut forever is a name known to allfordnut forever is a name known to allfordnut forever is a name known to allfordnut forever is a name known to allfordnut forever is a name known to allfordnut forever is a name known to all
Color back by turtle wax will take it off
New Old Hood SchwartzStock 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-20-2016 09:59 AM
Two tone question Barry Hagen 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 05-08-2015 05:12 AM
Bonus built COE going to scrapper frankcowan 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 09-05-2014 08:12 PM
1988 F250 hood? EKlev 1987 - 1996 F150 & Larger F-Series Trucks 4 02-19-2014 07:31 PM
C4 or C6? MKPJ1 1967 - 1972 F-100 & Larger F-Series Trucks 10 07-01-2002 09:07 PM
Tags
body, junk, junkyard, marker, markers, markings, marks, oven, paint, painted, parts, pen, pens, remove, removing, yard, yards
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
