97 Ranger A/C/Heater
1997 Ford Ranger 4.0L with a heater/AC control problem.
1) In any position of the switch (defrost, panel, feet,etc.) the A?C comes on unless I have it unplugged at the compressor.
2) I have heat at the heater core, but little coming out the vents,defrost, etc.
I checked the panel switch, feet,defrost, AC switch (4 wires) and found that as I look at the plug there is a 1)red/orange, 2) black?, 3)small purple and a small 4)white purple tracer. Checking with an Ohm meter no mater what position the switch is in the only continuity is between 1 and 2. Does this sound correct?
Your observation for #1 & #2 is correct. That is the ground circuit for the blower motor and the blower relay coil.
You should have continuity between #3 & #4 in any position that is supposed to call for A/C compressor operation. That is ALL positions EXCEPT OFF, FLOOR and VENT.
What happens if you disconnect either fuse F18 (I/P), the low pressure cycling switch, the high pressure cutout switch, or the A/C WOT relay?
Steve
Steve
bobo1950
1983 - 2012 Ranger & B-Series
08-20-2010 09:49 AM
dkilbarger
04-29-2001 06:56 PM
