where to add washer fluid for rear wiper/window? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-18-2014, 04:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Old 11-29-2008, 02:58 AM
turborich's Avatar
turborich turborich is offline
turborich is starting off with a positive reputation.
Where is the rear wiper fluid resovoir located? Is it in the rear or share the front one? I ask because the front sprayers work but the rear doesn't & I didn't see any resovoir in the rear.
Thanks.
Old 11-29-2008, 08:45 AM
Modified 99 Modified 99 is offline
Modified 99 is starting off with a positive reputation.
Smile
There is a common (shared) reservoir for the fluid. The spray nozzle at the rear could be blocked or clogged. Find a real fine strand of wire and open the hole. Don't be to aggressive when opening the hole, you could affect the spray pattern.
Old 12-03-2008, 12:32 PM
turborich's Avatar
Thanks for that info, I will check it out when the wife gets home.
Old 12-03-2008, 06:32 PM
pitrow pitrow is offline
pitrow is starting off with a positive reputation.
when I first got my expy the washer fluid hose for the rear had come off the nozzle, so when I hit it nothing would happen at first, but if I left it going for a while eventually fluid would start coming out the edge of the headliner. I had to drop the headliner in the rear and reattach the line. Have someone sit in the rear while you run the rear washer and see if they can hear fluid trickling anywhere.
Old 12-03-2008, 06:37 PM
heymrdj's Avatar
heymrdj heymrdj is online now
heymrdj has a good reputation on FTE.heymrdj has a good reputation on FTE.heymrdj has a good reputation on FTE.
When I bought my 04 it had this issue. Turns out it was the relay that decided which direction to turn the motor depending on whether it was sending the fluid for or aft. They did this repair for free at the dealership though before I got it, so I can't say much better.
Old 12-04-2008, 04:19 PM
jlamb30 jlamb30 is offline
jlamb30 is starting off with a positive reputation.
Quote:
When I bought my 2001 back from my ex, mine didn't work either. Found a joint behind the right front kick panel that had come loose. Hooked that back up, tried it, and it started raining fluid from the rear of the headliner trim and the rear dome light housing. Found that joint, hooked it up, been fine since.
If that is the problem, I suggest using small hose clamps or zip-ties, cinched down TIGHT, to keep them from coming apart again. I used zip-ties, because that's what I had on hand.
Skreechy sounds?? 199673Nick 6.4L Power Stroke Diesel 4 07-21-2015 02:32 PM
Wiper / Washer issue BassFantasizer Excursion - King of SUVs 0 12-09-2011 10:12 PM
pUT POWER STEARING FLUID IN BREAK FLUID RESOVOIR!!! JOHNNYRICH10 1999 - 2003 7.3L Power Stroke Diesel 17 08-08-2011 09:13 PM
Hard start unless plugged in zanks 1999 - 2003 7.3L Power Stroke Diesel 16 07-20-2009 07:46 PM
wiper fluid light on vyates1 1997-2006 Expedition & Navigator 15 03-01-2005 01:32 AM
Tags
08, 2003, 2004, 99, add, edge, expedition, fluid, ford, lincoln, motor, navigator, rear, washer, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
