strong fuel smell in exhaust fumes?
I know this means the mixture is rich and the carb needs adjusted on a carbed truck,but what about on a truck with efi? At idle standing outside the truck,the exhaust smells rich like unburned fuel. this is for my 95 f150 5.0. with long tube headers. it smells this way when the engine is cold or warmed up. there are no codes and the fuel pressure is within spec. I am not sure what else to check. if it were the o2 sensor,wouldn't the computer be throwing a code saying it is bad? thanks!!
32 psi was the fuel pressure at idle,and only moved a couple psi when the rpm was raised. I just checked to see if there was fuel in the fpr line,and there wasn't,so I am thinking it is ok. also fuel pressure was 40 psi when the fpr vacuum line was disconnected. i know the fuel pressure is supposed to be higher with the vac line disconnected,but is 40 psi too high?
I don't know a lot about this but here are some thoughts...
If the o2 sensor is only located on one side of the exhaust, maybe the sensor is only reading half of the emissions. These motors are bank fired aren't they? I believe that the stock exhaust systems usually locate the o2 in a connecting pipe on the y-pipe.
Also, if you have long tube headers, what did you do with the egr system?
on
on
According to Fordfuelinjection.com code 181 is " Right side still lean, at richest adaptive limit, during part throttle."
That means the O2 sensor is indicating A/F ratio is lean even though the computer has added as much fuel as it can. But the engine is actually running rich.. strong fuel smell in exhaust, so the O2 sensor is giving the computer bad info and most likely needs to be replaced. The only other way this could happen is if the air diverter valves were stuck and all the air from the air pump was being dumped into the heads or exhaust upstream of the O2 sensor.
Hey, how bout that? Most of the vacuum lines under my hood were cracked and brittle, so I removed them all and replaced only the critical ones like for the FPR. Then as I always do, I removed all the emission controls- less parts means more working room and less problems. I've been meaning to plug the lines that come from the heads that used to go to the air pump, but man I simply didn't realize leaving them open like I did would allow them to draw air in and make the o2 sensor read lean. No wonder I'm down to 6 MPG and my exhaust smells rich. I thought I left a vacuum port uncapped or something.
Sure am glad I read this thread.
dmhdsl
01-08-2012 08:36 AM
Violjohn78
12-30-2003 02:17 PM
