racing tach
sorry wrong link... this setup will work with hall-effect switches and pulse-generators... and should enable any tach to work with any signal.
here:
Universal Flywheel Tachometer Interface
may not work for your setup... I havent read the instructions... and it's not cheap! but it's somthing to consider... if you really need a "racing tach"
here:
This is closer to the stock tach sensor, it counts teeth on the IP drive gear.
Not sure if I would want to drill a hole in my bell housing, but I do get a little extreme with my loads.
But it should work if your tach is capable of working on a 4 cylinder mode.
The only issue left is anything over a 4000 RPM tach will never see any use.
Governed speed is 3600 at max RPM.
DWhiteyF250
16
07-30-2012 01:58 PM
