Coolant antifreeze leak 6.0 diesel. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-28-2008, 12:33 AM
TDITCH TDITCH is offline
TDITCH is starting off with a positive reputation.
'05 F-350 6.0 diesel, auto trans, 42,259 miles, rarely pulls a trailer or a load, stock and in very good condition. I bought this truck new Nov. '04. Todays date, 27 Nov. 2008. Now my first and only problem. I noticed on 25 Nov. 2008 that I have a large puddle of coolant under the truck. Only when the engine is totally cold does it leak golden colored antifreeze running down from what appears to be at the cylinder head gaskets at lower rear corners on both sides of the engine. My drive way is a slightly sloped black top and now with a stream of coolant running more than 30 feet out with a puddle the width of the truck under neath. The right side above the starter leaks much more than the left, a constant drip. 26 Nov. 2008 After adding one gallon of coolant mix up to the cold mark, I go to the selling dealer for this problem and an oil change and fluids check. The invoice tells me they replaced a hose clamp part number B7A*8287*AA, changed the oil and filter, performed the multi point inspection noting all fluids are full, that I have a week battery and one front tire may require future attention. I paid the 149 dollar and 50 cents bill and drove 7 miles home. Next day, today 27 Nov. 2008 my neighbor and his friend comes over to tell me they noticed antifreeze leaking from under my truck. At this point I will not mention to what agency in Ann Arbor, Mi. his friend works for but I will say that he was very concerned. Photos and a video have been taken. I raised the hood, looked around, found no leaks anywhere, nothing wet, power steering fluid still below the add mark, dark engine oil and a constant drip mess of coolant in my drive way coming from the same places as mentioned above. In the morning 28 Nov. 2008 I'll return to the Belleville, Mi. dealer to try once again to get this matter taken care of. Comments from any one?
Old 11-28-2008, 11:17 AM
Powerstroke_wannabe Powerstroke_wannabe is offline
Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.
Sounds like it may be the coolant line going into your EGR cooler.
6.4L Lower left coolant leak Laner 6.4L Power Stroke Diesel 20 07-07-2014 10:14 PM
I need help: coolant system woes Jesser02EX 1999 - 2003 7.3L Power Stroke Diesel 26 07-06-2014 04:33 PM
2000 Expedition Leaking Antifreeze from above Catalytic Converter brimis 1997-2006 Expedition & Navigator 6 07-10-2013 11:36 AM
Cooling system problem?? DesertStorm 1999 - 2003 7.3L Power Stroke Diesel 8 06-22-2012 09:10 PM
coolant coming out the exhaust 06NEWTOME 6.0L Power Stroke Diesel 19 02-06-2011 09:55 AM
Tags
60, anti, antifreeze, black, coolant, coolantantifreeze, diesel, f350, ford, fords, freeze, golden, leak, leaks, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
