Transmission upgrade - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-27-2008, 11:42 AM
BSF350 BSF350 is offline
BSF350 is starting off with a positive reputation.
Will a 06 ford diesel auto trans bolt and work with a 01 7.3?
Old 11-27-2008, 11:54 AM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
The problem is the torqueshift tranny is computer controlled, and our computers are not capable of running them. If you want a bulletproof tranny, look into a BTS (brians truck shop).
Old 11-27-2008, 12:03 PM
UP_There's Avatar
UP_There UP_There is offline
UP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud of
Quote:
I haven't heard of anybody pulling this off. It would require MASSIVE changes to your PCM. The 5R100 transmission is completely different the the 4R100. It'd be a LOT better going with either a BTS or a John Wood tranny, either of those are far better then the 5R100 anyways
Old 11-27-2008, 12:18 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Quote:
It would also be far cheaper in the end than trying to mate a 5R110 to a 7.3. Plus, if you manage to blow up a BTS (which he'll DARE you to do, BTW), it has a 2 year no matter what warranty, and a lifetime parts/labor warranty (pay only shipping to & from BTS).
Old 11-27-2008, 03:07 PM
Meatco1's Avatar
Meatco1 Meatco1 is offline
Meatco1 is starting off with a positive reputation.
Much cheaper to rebuild with either John Wood, or BTS transmission. Both have outstanding warranties, and are near indestructible with normal driving & towing habits.
I seem to remember a JW tranny going into a 1300 hp truck last year.
Respects,
Richard
Old 11-27-2008, 09:57 PM
Bigfwt04's Avatar
Bigfwt04 Bigfwt04 is offline
Bigfwt04 has a good reputation on FTE.Bigfwt04 has a good reputation on FTE.Bigfwt04 has a good reputation on FTE.
what kind of price for a BTS?
Old 11-27-2008, 10:23 PM
strokersace's Avatar
strokersace strokersace is offline
strokersace has a very good reputation on FTE.strokersace has a very good reputation on FTE.strokersace has a very good reputation on FTE.
One thing nobody mentioned is if the bell housing on a 5R110 is the same?? I'm not sure if it is or not.
As for the controlling of the the 06 tranny if it did bolt up, you could use the same controller Jeremy (jtharvey) used when he destroked his ford.
I believe it's called a PCS - powertrain contol system. Or something similar to that. They run under $1000 I think, and everything I've heard about them is they are awesome!
If the bellhousing bolts up to the 7.3, then it could be done.
BTW - As others have said though, a John Woods or BTS trans would be a custom built alternative for your truck. They'll be in the $4000 range and more if you have it shipped.
Old 11-27-2008, 10:30 PM
UP_There's Avatar
^^^^ Huh?
Old 11-27-2008, 10:44 PM
^^^^ Huh?
To which part??
Here's the link to Bean's website about the PCS:
Beans Diesel Performance - Programmable Electronic Automatic Transmission Controller by PCS (Powered by CubeCart)
When doing a cummins conversion backed by a ford trans or even with an Allison tranny, these are used to control the tranny.
That's why I say, if the 5R110 would bolt up to the 7.3, then I'm pretty sure it could work. Use this PCS to control the trans instead of the factory PCM.
Old 11-27-2008, 10:48 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
Yes, the PCS controller can "make coleslaw" if you configure it right, and i want one to manually control my trans with a joystick one day. Thats a future project... If it can be bolted up (destroked wouldnt have a problem making a 7.3->5R110 adapter plate) it can be controlled
Old 11-27-2008, 10:58 PM
That_Guy's Avatar
That_Guy That_Guy is offline
That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.
Quote:
$4100 IIRC
Old 11-27-2008, 11:24 PM
$3900, plus a 6.0 cooler, fluid, tax etc, mine was $4601
Old 11-27-2008, 11:58 PM
That_Guy's Avatar
The told me when I called in the begining of the year that as of the first they upped the price to 4100 plus all the extra stuff..
Old 11-28-2008, 12:29 AM
Doesnt suprise me, with all the rest of the world raising its price.
Old 11-28-2008, 01:25 AM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
I asked the same question awhile ago, thinking yeah a 5 speed auto T/S would be nice.
I have known a few guys personally that have had these T/S trannies blow on them, and I would take a second to check that out before considering one.
I wonder if destroked wouldnt make an adapter for an allison tranny to go in there.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Exhaust (cat) 1987 - 1996 F150 & Larger F-Series Trucks 7 08-23-2012 12:39 AM
Tags
2005, 4r100, 5r100, automatic, az, brians, bulletproof, f350, ford, price, problems, rebuild, sale, shop, transmission, truck, upgrade, upgraded
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
