1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Strange inside-edge tire wear.
Old 07-20-2014, 12:31 PM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
NM - thought I read 2WD.. Is it too early for a beer???
Old 07-20-2014, 02:14 PM
Field Truck's Avatar
Field Truck
Field Truck is offline
Originally Posted by Noman
I am having the same problem on my 2003 F350 LE super duty 4x4. This is the third set of front tires that have worn on both the inside and the outside. The center of the tires are almost like new when the inside and outside are nearly worn through.
I run 90 PSI in them or they look half flat. I think it is the weight of the diesel engine that puts so much weight on them. I tried 50 lbs an went through a set of tires in 7,000 miles. With 90 PSI I get about 12K.
The wear starts with evey other lug both inside and outside and only about 1.5 inches in. Then within about 10,000 miles the tires are gone. I have had it aligned twice with no help from it. I am now looking at replacing most of the front end joints.
How many miles on the front end and what front end parts have been replaced, if any?
Old 07-21-2014, 05:16 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Are they E-rated tires? Sounds like they are passenger car tires. What's the MAX PSI on the sidewall?
Magnolia Tom
25
07-01-2020 10:58 PM
clintbonnie
6.2L V8
10-21-2015 08:25 PM
olyellow
1983 - 2012 Ranger & B-Series
10-04-2014 09:40 AM
nomad221
08-01-2013 11:49 PM
2kredexc
07-22-2001 01:51 PM
Quick Reply: Strange inside-edge tire wear.
