Guage cluster removal
It's pretty straight forward. You first start by removing the lower panel right below the steering column, this will expose the fasteners that you will need to remove in order remove the bezel surrounding the cluster itself. To remove the bezel I just described, you will have to pull toward yourself carefully once it's loose you lift up and away from the cluster. Once you remove the bezel You will notice the 4 fasteners securing the cluster in place. Before you can pull out the cluster itself you need to remove the gear shift indicator by pressing against 2 pins located on the left and the right of the gear shift indicator. You have to reach in from under the cluster to push those pins, so you should have the steering column lowered the the lowest point. I can't remember if I pushed the pins toward the center or out to the sides but once you do it the gear shift indicator slides right out. You have to actually get in and reach inside with you fingers into the area where the gear indicator is. Let me know how it goes or if you need any more info. I can probably email you a pdf if u run into trouble.
nstueve
29
05-21-2017 06:28 PM
ewellman
10-07-2003 03:38 PM
