92 2.3L CKP - Replacing the Crankshaft Position Sensor - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-26-2008, 09:31 AM
RixWorx RixWorx is offline
RixWorx is starting off with a positive reputation.
Per the manual I need a Ford tool T89P-6316-A Crankshaft Hall Effect Sensor Positioner to install a new CKP.
For Dealer says they don't use or sell that tool.
How do you set the position of the sensor?
Rick
Old 11-27-2008, 07:23 PM
643NRK's Avatar
643NRK 643NRK is offline
643NRK is starting off with a positive reputation.
In my Chilton manual it does not say anything about that tool. It says:
"Position the sensor against the engine front cover, then install the mounting stud/bolts. Tighten them until snug.
Install the CKP sensor cover and retaining nuts; tighten the nuts until snug.
Reattach the wiring harness connector to the CKP sensor.
Connect the negative battery cable."
Old 11-27-2008, 07:26 PM
B A dawg B A dawg is offline
B A dawg is starting off with a positive reputation.
Are you possibly confusing the CMP/ CKP?
The CMP (camshaft position sensor) was not used on a 92. Only 94 CA 2.3's and then 95-99 49 state 2.3's used CMP's.
I think you're reading the CMP R&R procedure for 94 CA 2.3's.
For the CKP, according to my manual, it's a simple R&R.
CKP is located on engine front cover.
Unplug the connector, remove the sensor cover, if equipped, remove the sensor retaining bolt, remove the sensor. Reverse to reinstall. No torque spec, tighten all bolts until snug.
Hope that helps.
Old 04-03-2011, 06:04 PM
trav4907 trav4907 is offline
trav4907 is starting off with a positive reputation.
R u sure?
Ya I was wondering if u r a 100% sure that there is no camshaft position sensor in a 1992 ford ranger 2.3l? I have been looking everywhere because I heard it may be my problem and the auto parts store seems to have one for it. I'm just not sure? I hope u can tell me. Thank u very much.
Old 12-30-2015, 05:31 PM
jbcaesar44 jbcaesar44 is offline
jbcaesar44 is starting off with a positive reputation.
I had a mechanic replace the CKP on my 89 ranger because it wouldnt start. when I picked the truck back up I drove it a few miles and it quit, got a ride home went back the next day to tow it and it started up, drove it on home it died in the driveway. truck would run after the engine cooled off but would die before you could go more then a few miles. long story short sencor was not gaped correctly and when crank got hot it would expanded makeing contact with sensor. So tool or not correct gaping is important.
EEC components and what they do Racerguy 1997 - 2003 F150 18 11-02-2016 07:26 AM
Camshaft Position Sensor (CMP) wiring pigtail replacement dchamberlain 6.0L Power Stroke Diesel 12 06-07-2016 12:13 PM
5 Volt location for fuel pressure sensor? white Buffalo 6.0L Power Stroke Diesel 20 02-03-2016 11:01 AM
Cps therigwelder 1994.5 - 1997 7.3L Power Stroke Diesel 42 12-19-2015 10:02 PM
Crankshaft/Camshaft Sensor Range/Performance jrgoffin Explorer, Sport Trac, Mountaineer & Aviator 1 02-08-2010 08:56 AM
Tags
23, 23l, 94, camshaft, crank, crankshaft, effect, equivalent, ford, hall, mazda, position, positioner, replacing, sensor, t89p6316a
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
