Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-26-2008, 05:56 AM
old farmer old farmer is offline
old farmer is starting off with a positive reputation.
1947 Mercury Grille
I have a '47 Mercury truck, basically a Ford with different trim.
How does the grille attach to the front panel?
Is the front panel the same as the Ford?
The grille is different from the Ford, the Ford is 5 groups of 3 vertical bars, but the Merc is horizontal bars, 6 levels, 1 on each side attached together to a cast piece in the middle.
Here is what it looks like:
http://www.majesticscarclub.com/Stan...ry%20truck.jpg
Thanks.
  #2 (permalink)
Old 11-30-2008, 01:51 AM
46fordtruck's Avatar
46fordtruck 46fordtruck is offline
46fordtruck has a good reputation on FTE. 46fordtruck has a good reputation on FTE.
I have one of these grilles in my garage, complete panel and all from a '47 Merc. The grille panel is the same as the Ford, however, as I'm sure you know, the mounting holes for the bars are different. The Merc bars had special brackets that attached it to the panel, at the ends of the bars. If I recall correctly the panel still does have the mounting holes for the Ford grille bars, all the various trim pieces for the Merc just cover it all up.
__________________
Gary-
Down to only one, a 1946 1/2 ton
Collector of anything related to 42-47 Ford Trucks
  #3 (permalink)
Old 11-30-2008, 10:53 AM
3Mike6 3Mike6 is offline
3Mike6 has a good reputation on FTE. 3Mike6 has a good reputation on FTE.
That Merc grill sure makes these '42-47's look nicer.
  #4 (permalink)
Old 12-01-2008, 01:25 PM
Hi 46fordtruck, thanks for answering. Another question.
The grille is assembled now, but some pieces are real tight into the front panel. The parts come further away from the front panel towards the center. There is enough room to slide my fingers in between the grille center and the panel center. But I can't just push it in, the tabs at the ends are already in tight. Is there some kind of trick to this or is there a piece that goes in behind the centers to take up the space?
  #5 (permalink)
Old 12-08-2008, 07:59 PM
old farmer, I'm not sure as the grille I have is all disassembled right now. If I get a chance I can check it out and see if I can see how it all goes together. But if I am reading your post correctly, do you have a sheetmetal bracket that bolts to the die cast center piece of the grille bars?
__________________
Gary-
  #6 (permalink)
Old 12-11-2008, 10:39 PM
We got it together, finally.
We have all the pieces, we had to make little cuts in the panel and pull the metal back on the ones that wouldn't fit. I don't know why it was like that.
But it's all together now and looks right.
Thanks for the help.
  #7 (permalink)
Old 12-18-2008, 11:06 AM
SStans's Avatar
SStans SStans is offline
SStans is starting off with a positive reputation.
....hey ol farmer, that picture of the green Mercury... its mine. Its a 46. Taken a year or so ago. Stock flathead power. I still own it...it still looks the same. Stan.....
  #8 (permalink)
Old 12-18-2008, 12:07 PM
SStans's Avatar
  #9 (permalink)
Old 12-19-2008, 02:56 PM
SStans's Avatar
...Pictures of a Mercury grill on a parts truck I have. Havin trouble getting words and pics in the same square... Stan. .............
  #10 (permalink)
Old 01-04-2009, 09:54 PM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of
Hi Stan, welcome aboard and congrats on the fine fleet of Mercury and Ford trucks.
Please turn on your email and PM accesses in your user control panel, I have a message for you.
__________________
Fomoko1..Morris
Chapter Leader Manitoba/Saskatchewan
1927 Model T Touring
53 M350, 56, 57 & 71 F350, 53 & 56 M100
89 & 98 Ranger XLT s/cab
92 F250 XLT Super Cab 4X4, 05 F350 6.0 4X4Lariat Crew
65/67 Mustang Fastbacks/68 convertible
57 Ford 800 tractor, 86 & 88-LN 8000 Ford trucks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
