Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-26-2008, 01:46 AM
Beanscoot Beanscoot is offline
Beanscoot is starting off with a positive reputation.
Bronco 2.8L into early Corolla
I have had this Bronco II engine sitting in my basement for years now, and was thinking about putting it into a 1970 Corolla to replace the 1100 in there now. It should physically fit, but does it make more sense to find a bigger V6, i.e. the 4000? Or perhaps the 2800 would be plenty for this little car. The 2800 engine also has a cast iron timing cover and brackets which seem rather unnecessarily heavy. Are there later model parts which could substitute?
I will use a carburetor, so is it possible to adapt components of the 2800 (heads and intake) onto a 4000?
Or is it just impractical to put either engine in, and perhaps I should use something else? Again, I plan on using carburetion.
Thanks for any advice, pro and con.
  #2 (permalink)
Old 11-26-2008, 10:32 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
You might be able to swap some 2.9 aluminum brackets, but I don't think the T-cover will work (I think it's cast iron anyway.)
As far as swapping heads from either 2.9 or 4.0, there are several reasons why this won't work. Chief among them is that the valves and ports are in a different arrangement on the later heads, which would mean swapping the cam as well. But that won't work because the 2.8 cam is gear driven and rotates opposite crank rotation while the 2.9/4.0 cams are chain driven and rotate in the same direction as the crank.
It's frustrating because the 2.9 is tantalizingly similar to the 2.8, but there's not a lot there that will work (at least that would provide any performance upgrade.)
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
