65 F100 Suspension Bushing Help
I am no mechanic and need some help with replacing the bushings for the rear suspension.
I want to replace the spring eye bushings and shackle bushings on the rear springs. How do I get these out of the springs and spring shackle? I have tried beating them out with no luck.
I am thinking I need to go to a machine shop and have them pressed out. Is this how the new ones will go in?
you can remove the old bushings with a torch if you have one,
After you remove them from the truck!!Doh! Will you be replacing them with rubber ones, or polyurethane ones. just asking....... Press the new ones in with a little lubricant Could almost do that with a Big vice, but better to have a shop do it for you.
Jonnys.1991
03-02-2015 12:27 PM
jjuchems
10-18-2010 10:12 AM
wilerboy
02-17-2010 05:00 PM
