gas gauge shows half when empty - Ford Truck Enthusiasts Forums
Old 11-25-2008, 02:42 PM
merlynr's Avatar
merlynr merlynr is offline
merlynr is gaining momentum as a positive member of FTE.
Question gas gauge shows half when empty
I have a 71 F350 and the gas gauge shows half full when empty and when fill it up it goes way past full. I pulled the sending unit from tank and checked resistance and it changed from 10-50 ohms when moving the float lever. checked another sending unit I had and it measured the same and so I put it in and gauge reads the same with it. Both floats were good and the rods were bent the same. I'm thinking it's the gauge itself. Can it be tested?
Old 11-25-2008, 02:50 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
If you end up needing a new dash fuel gauge, Don Sanderson Ford in Glendale AZ has 27 of them available: 623-842-8762
C7TZ9280B .. Fuel Gauge-Dash / Obsolete
Fits: 1971/72 F100/350 / 1971/74 Econoline
Old 11-25-2008, 07:56 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Those units should be 10-90 ohms if I remember correctly. To test the guage and the wiring going up front, go back to the sending unit and take the wire off, and with the key in run, have someone watch the guage as you ground the sending unit wire, and then take it off ground and let it hang in the air. If the guage goes full scale back and forth when you do this, then it and the wiring are good.
Old 11-26-2008, 08:58 AM
merlynr's Avatar
Ok, thanks for the info. I'll try that this morning. Maybe I'll check my vom also for the readings. If 10-90 ohms is correct, I may need a new sending unit.
Old 11-26-2008, 10:58 AM
Franklin2's Avatar
If you decide there is something wrong with the sending unit, I would go ahead and take it apart. I have had a 100% success so far repairing sending units in old trucks as well as newer vehicles. Just carefully bend the 4 little tabs up straight, and you can take them apart. Half the time I have found the little brass wiper inside is cracked or completely broken off. I just solder them back together with my soldering gun.
Old 11-26-2008, 01:38 PM
merlynr's Avatar
Well the gauge is ok as it responds to the grnding/open test with key on. Maybe I'll take the sending unit apart that is not in truck now and see what's up with the rheostat.
gauge reading opposite of what it is chromeaholic 1987 - 1996 F150 & Larger F-Series Trucks 22 10-28-2013 09:15 PM
78 F150 fuel gauge buzzurd 1973 - 1979 F-100 & Larger F-Series Trucks 14 04-17-2013 11:53 AM
1991 E350 RV fuel gauge issue... lhutter1 1968-2013 Full Size Vans 3 01-15-2013 07:06 PM
Fuel Tank Sending Unit Problems??? velcro7279 1966 - 1977 Early Broncos 11 08-05-2007 06:38 PM
Anyone with fuel gauge problems;read stroker393 Electrical Systems/Wiring 1 06-09-2003 07:31 PM
Tags
2004, broken, c7tz9280b, empty, f350, ford, fuel, gas, gauge, guage, half, reads, showing, shows, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
