Ford 6.6 Diesel swap ideas
Last I called, a 6.6 was $1500 for a good runner, which is 1000 less than an equally equipped 6BT. The issue with the Ford would be to get the linkage to the other side. You will also possibly get an air compressor with the Ford. There's always a way, and too many options and ideas to put in a post. Last note, if you look for performance stuff, and check on pulloff.com , they often show tractor pulling stuff. Mostly listed as Ford 401. The 93's had a bosch P-pump, hint-hint.
I had started a DT466 swap in a Sooper Dooty a couple years ago. It still hurts, having to sell it off. If you cant tell by the link in my sig, I like the med duty truck engines. The secret to power is in the pump.
I found a 6.6 for $500, but it doesnt say if there's anything wrong with it. The bonus, is that it was aftercooled(CAC/ intercooled).
ACME Truck Parts & Equipment Inc. - Detail Information for FORD 6.6 Engine Assembly #1245
What's funny, is this thread still gets lots of hits per month. Time to bring it back from the 2 year old death. I actually bought the engine from Acme in the link above, and that's what I'll be slipping in my 67 F100.....someday. Wonder if the original poster would want to trade my manual setup for his Allison setup?
how many horsepower would it?
My 6.6 engine was original aspired ,after was turbo , instaled
engine connecting rod of the turbo and pump injection with advance ,
after new injection pump he reaches 3500 rpm, before only reaches 3100-3200 rpm
It have 188 HP @ 2400rpm but can reach 190 195 hp with instaling intercoller and more diesel dosege !
here have 7.8 with 285 hp @ 2300 rpm
seeing in google have much ford diesel engines for buy in USA , and very truck that equiped with it ! but very short differential ratio, reaching low speed!
#30
Yes, with some work.
