Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 11-24-2008, 10:27 PM
glkearns glkearns is offline
Garage is empty, add now
glkearns is starting off with a positive reputation.
P 171, 174(bank 1/2 too lean) codes
So, over the past couple of weeks I have been trying to get rid of the above codes, Here's what I've done.
Changed fuel filter
2 bottles of injector cleaner
tune up(plugs wires cap rotor pcv)Did this step because of another code(don't recall the number but it was a misfire in cyl 6)
After all of that I am stuck, the MIL is back on after just a few miles, and It is still missing intermittantly mostly at highway speeds.
What's next? Injectors? commercial grade injector cleaner(jiffy lube?)
Its a 96 4.9l 5speed with 225k on the ticker
Greg
  #2 (permalink)
Old 11-25-2008, 07:01 AM
whsmith_jr whsmith_jr is offline
whsmith_jr is starting off with a positive reputation.
Key in on things that will impact both banks. I had this same problem on my daughters 95 Mustang (3.8). I found a couple of vacuum leaks, but that didn't fix the problem. I noticed that the Baro reading was reading like we were at around 5,000 feet, but we are close to sea level. I cleaned the MAF and the Baro reading corrected itself. The codes have not been back!
Smitty
  #3 (permalink)
Old 11-25-2008, 07:45 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
These codes are telling you the computer has made as much adjustment as it can but the right side O2 sensor still isn't switching, this probably means the sensor is bad if there are no other codes. If you had codes indicating both banks were at adaptive limit then I would suspect a fuel pressure problem or blown FPR but that's not the case.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1990 2.3L 5-sp Ranger 3.08, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
  #4 (permalink)
Old 11-25-2008, 01:34 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman NewEnglandHerdsman is offline
Moderatee...
NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.
Correct me if I'm wrong, but P171 AND P174 means both banks are lean... Since the likelihood of both sensors going bad at once is pretty slim - so a fuel delivery problem is more likely, yes?
I'd second checking the fuel pressure and pressure regulator...
__________________
Jim - - Official FTE Forum "Wet Blanket"
2006 F-350 5.4 4wd ---2012 Escape Limited 4wd -- 2008 Escape XLT
4wd --- 2004 Mustang ---
"A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty. " Churchhill
  #5 (permalink)
Old 11-25-2008, 01:53 PM
Conanski's Avatar
1990 Ford F-150
Yes.. '96 F150 is OBD-2 which makes a difference.. I was looking at OBD-1 codes.
__________________
  #6 (permalink)
Old 11-25-2008, 11:35 PM
Found 2 vacuum leaks today, and repaired...seemed to help a little bit, but we'll see if the code returns.
Greg
  #7 (permalink)
Old 12-05-2008, 08:04 PM
William Green William Green is offline
William Green is starting off with a positive reputation.
Hey glkearns we got the same problem same year what the hell I pulled my back tank and bad fuel pump and toss it behind the shed and rerouted the plumbing still a low pressure on the injectors so says the mechanic at the shop now I have to replace the other fuel pump it's always something let me know how you solve your problem.Thanks
  #8 (permalink)
Old 12-06-2008, 01:48 AM
Check your vacuum lines. My codes havn't been back. Now I am just waiting for all the self checks to get done to pass smog. I'm changing my t'stat out tomorrow (back to a 195 deg from 160 deg) apparantly it's not exiting warm up and the computer won't complete the self tests without...If that's not it, I start changing o2 sensors.
greg
Tags
171, 171174, 174, 1996, 96, 97, bronco, code, codes, f150, ford, lean, obdp171code, p171, p174, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
