Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-24-2008, 09:31 PM
Dragonfox13 Dragonfox13 is offline
Dragonfox13 is starting off with a positive reputation.
2.3 fairmont
ok, weve got a 2.3 from a 78 fairmont in our skidloader and need to put a timing chain on it, but not sure where the notches on the cam and crank are supposed to be, anyone with some help would be greatly appreciated..
__________________
1995 1/2ton 2wd 5.0l AOD tranny
  #2 (permalink)
Old 11-24-2008, 09:41 PM
Econoline 150's Avatar
Econoline 150 Econoline 150 is offline
Econoline 150 is starting off with a positive reputation.
It should be a timing belt. I think theres two notches on the cogged pullyeys, been a long time.
__________________
Bill Lloyd
1981 Ford F250 4 x 4 351M & 4 speed
1982 Ford Econoline 300 six
  #3 (permalink)
Old 11-25-2008, 08:55 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
Squaremont! There is a pointer on the cam pulley, triangle shaped, and you rotate it to line up with a pointer mounted on the front of the block. The crankshaft key would be at 12:00 for TDC. The distributor pulley - rotate to put the rotor pointing at #1. Loosen the tensioner (two bolts) and push the idler back against spring tension. Thread the belt over all the pulleys, loosen the tensioner bolts and allow the idler to push against the backside of the belt. Rotate 2X in normal direction, put back at TDC, and check for pointer alignment. If they align, tighten down the tensioner and replace all the other parts... Then set the timing to 10btdc.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
Tags
belt , explorerer , ford , notches , tensioner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
