Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 12-24-2008, 10:18 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
Biodiesel Guru
fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold
I have several adjustable power supplies in my lab, including one that will produce up to 3,000 VDC@ 1 Amp..............
__________________
FABMANDELUX.
Don.
Oregon Chapter Leader: To join the Oregon Chapter, click HERE
  #17 (permalink)
Old 12-24-2008, 11:02 AM
97biostroke's Avatar
97biostroke 97biostroke is offline
97biostroke is starting off with a positive reputation.
Sounds like you've got quite the setup. Just to clear this up, using the electrostatic field while mixing the methoxide and WVO will cause it to react and separate within 5-10 minutes, right?
  #18 (permalink)
Old 12-24-2008, 11:27 AM
uliman uliman is offline
uliman is starting off with a positive reputation.
The Mcgyan Process is not so new (the article was written in 03/08) and since that time there have been several articles written on it as well as at least one TV documentary. I concur with the others that this is the way to go for the future but it will require an enormous amount of capital investment. I think T. Boone Pickens may be involved in this as well (in addition to his windfarms).
I truly believe that biodiesel production from algae will eventually free us from the Oil producing countries but in the meantime we have to contend with the big oil companies who are not going to go away easily and will continue to extract every cent of profit they can from us oil-guzzlers. Why get rid of a cash cow until no more blood can be squeezed from it?
Economics 101 was openly displayed in the last six months or so when the US consumption of oil declined (I think about 3%) for the first time ever. That, I believe, is largely responsible for the decline in prices. OPEC just recently got together and decided to cut production in order to get the price of a barrel back up there (just the old supply/demand principle at work!!)
Just my two cents.
__________________
01 F350 DRW CC Lariat 4wd, JW Towmaster, 6.0 trans cooler, Dipricol 3-gauge pod + F5, 4" MBRP, DP Tuner, AFE Stg 2, CCV mod, 203 stat, Foil Delete, A.R.T. Cryo Slot Rotors, Type 02 ULTRA Rims, BFG KO, Line-X, B&W Gooseneck, KR Bumpers, Siderails, Running Boards, 02+ Lamps, Custom Chrome Grille, Alum. Rear Diff. Cover - Royal Purple 90/140w
  #19 (permalink)
Old 12-24-2008, 11:33 AM
zhilton's Avatar
zhilton zhilton is offline
2004 Ford F-250
My Garage
zhilton is starting off with a positive reputation.
We all agree that it's quite possible that biodiesel produced from algae; but what about motor oil? My 365VGT has to have it's oil changed regularly...so I'm wonder, do we still use dino based oil...or is there something else out there?
__________________
1972 Ranchero GT 351C (Engine code "Q")
2001 Explorer XLT 2WD
2004 F250 PSD CC Lariat 2WD "Pavement Princess" (bone stock...for now)
  #20 (permalink)
Old 12-24-2008, 06:58 PM
Biodiesel Guru
Quote:
No, the electrostatic separation occures after the normal mix cycle is compleated.
The use of HV during the mix phase would result in the potental for a big boom!
__________________
FABMANDELUX.
Don.
  #21 (permalink)
Old 12-24-2008, 07:03 PM
Biodiesel Guru
Quote:
Yes, "there's something else out there" The food industry already uses veggie based oils, and grease. The US Gov uses it also. For most of us the price is just to high at this time, but as demand increases the price should go down.
__________________
FABMANDELUX.
Don.
  #22 (permalink)
Old 12-25-2008, 02:01 AM
Ok I thought the video showed it during the mixing process, and I thought that could be pretty dangerous. On the youtube video site, they said a burner ignition coil would be a good source for HV and low amps. What exactly are they talking about and where could i find one? Or any other cost effective ways to get HV and Low amps?
  #23 (permalink)
Old 12-29-2008, 09:44 PM
Tom D Tom D is offline
Tom D is starting off with a positive reputation.
How about a transformer from an old neon sign?
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #24 (permalink)
Old 12-29-2008, 11:05 PM
That could work. Has anyone else tried the electrostatic glycerol separation? Im curios about the specs on how many amps and volts work the best, and how exactly to set it up.
  #25 (permalink)
Old 12-30-2008, 01:11 AM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is starting off with a positive reputation.
Synthetics. The price is already low enough that with extended service intervals it is comparable to using dino.
I use Mobile 1 in my wife's Jeep. After a fresh oil change we drive it 3500 miles, change the filter, top up the oil (to replace what was lost during the filter change - about 1 quart) then drive it another 3500 miles.
So I get 7000 miles for the cost of 7 quarts of synthetic @ $7.89/quart = $55.23/7000 miles = $.00789 per mile
vs.
3000 mile oil changes with regular oil - 2 oil changes = 12 quarts of regular oil at $3.99/quart = $47.88/6000 miles = $.00798 per mile.
__________________
1986 F250 Super Cab 4x6 (dually), 6.9 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
SOLD! 1986 F250 Super Cab 2WD, 6.9 NA, C6 Auto, 3.55 gears, K&N, dual RAM-air, custom Y-pipe to 3" ATS exhaust. 120k? 220k? Dunno’ but still running strong when she left...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
