cleaning alum trim
There are a few products to seal or coat aluminum, Eastwood carries a couple of different types including a product called 'zoot' it has a 2 yr. warranty and for that limited amount of time, IMHO, seems expensive. Redid 65 grille few yrs back and purchased a can of clear at the local auto supply shop to coat the grille. It's beginning to show some wear and looks like it could use another coat. If it came to a redo I would look into whether there is a clear color 'powder coat', seems it would hold up longer. Read an article where the author is in a spray both applying a clear coat to alum. rims at the same time an electrical charge is applied, simular to the anodizing process only with out the solution and dipping tanks.
That may be the case, maybe yours wasn't as badly oxidized as some. All the trim on the dentside trucks were anodized aluminum. But if you think yours shined well...you've obviously never seen a brand new set, or a refinished set. I'm gonna have to take some pics of the sets I have when I get home. I have a set of 30 year old trim (looks like silve paint), buffed trim (a little glimmer of shine), refinished trim I did (driver quality), refinished trim I had my body shop do (can start seeing yourself in it), a brand new set from DC (showroom condition), and a set that I had chromed (looks like you're looking in a mirror). And the shine increases exponentially in the order that I listed them.
Just curious if you ever got some pics taken?
My dent trim is in great shape, but the grille I picked up from recently, although in great "physical" shape could use a nice refinish once my truck is painted.
I know about the Easy-Off trick, but once the anodizing is stripped what is the process after that?
Josh
cbfomoco
03-25-2006 09:59 AM
