'92 died, and restarted...?
Old 11-24-2008, 01:17 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
I jumped in my '92, 300, truck this evening, turned the key to on, listened for the relays, etc. and went to turn it over. Hit one crank, then acted like it completely shorted out, and then it came back to life and cranked after 2 or 3 rotations...
I'm sorta stumped, not completely sure if this has happened before.. I just inspected and cleaned all grounds, installed a new starter solenoid(old one was pushing up daisy's"), and looked but don't see where my new alt connection could be making for a short...Anyone have this problem before or encountered it?
After I drove it for about an half-hour, I shut it off at the house, let it sit a moment, and tried again, it cranked fine. It cranked fine yesterday after my new alt conn. and my new starter solenoid. Also the weather was dry and cold, so I'm ruling out condensation and moisture.
Also changed the neutral saftey switch as of 12/06.
What a bummer for small hiccups!
Old 11-24-2008, 07:01 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
It sounds like bad battery connections. Have you cleaned and tightened those? Have you examined the battery wires for signs of heated insulation or corroded wires?Have you checked that the wires connected to the starter are tight?
Old 11-24-2008, 08:25 AM
quicklook2's Avatar
quicklook2
quicklook2 is offline
bad batt. connection is my guess also.
dbail3
Electrical Systems/Wiring
09-18-2014 07:07 PM
Pitcrw6
08-26-2012 12:59 PM
strokin'_tatsch
04-18-2010 06:41 PM
BCrespillo
12-30-2005 07:17 PM
lmadore
09-10-2004 09:54 AM
Quick Reply: '92 died, and restarted...?
