Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Nebraska Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Nebraska Chapter Join Chapter, Leader: 97nukeford
  #1 (permalink)
Old 11-23-2008, 10:48 PM
FordTrucksKickGM FordTrucksKickGM is offline
Garage is empty, add now
FordTrucksKickGM is starting off with a positive reputation.
Power Steering Input Seal Replacement
Hopefully someone can help me out with this. On my 78 F-250 4x4 I added hydroboost brakes so with the extra pressure the input seal at the gear box decided to give up on life. Ive gotten as far as removing the steering shaft and the rubber dust seal at the input shaft. Whats the trick to get the seal out? Theres no snap ring or anything to remove. There are 4 bolts that mount the end housing (where the hoses connect) to the main body and it looks like if I were to take that off I could get to the seal from the back side and pound it out. I just wanna make sure Im on the right track here.
Thanks
  #2 (permalink)
Old 11-23-2008, 11:16 PM
This is turning into a learning experience. I removed the 4 bolts and separated the gear box. So now Ive got the input side of the gear box off and at least its a little easier to work on. I found theres a metal dust shield and I got that off. Then I found the snap ring and removed that. Now Im trying to figure out how to get the actual seal out. I did find that my ps return hose was kinked so that was probably why the input seal blew in the first place.
  #3 (permalink)
Old 11-24-2008, 12:05 AM
Well with the help of google I figgered it out. After you remove the snap ring you put the housing back together and hook up the pressure line and plug the return line. Crank the motor and the pressure will push the seal out. If I woulda realised there was a metal dust cover and snap ring I wouldnt have had to split the gear box. You learn something new every day.
  #4 (permalink)
Old 11-24-2008, 09:01 AM
67nukeford's Avatar
67nukeford 67nukeford is offline
Nebraska Chapter LDR
1997 Ford F-150
My Garage
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
Hey Mark, glad to see you got it figured out!
__________________
Pat W. Nebraska Chapter Leader and Official #1 Slackmaster/ Avid Winter Hater
2006 F-250 "Black" ARP studs, EGR delete, SCT tuner REBUILD THREAD
1967 F-100 4X4
1967 F-100 Project thread
2013 Explorer XLT (wifeys)
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
Tags
box, ford, gear, input, power, replace, replacement, seal, seals, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
