"If there all the same apples, most likely.
Will you run into some problems, most likely.
The things you will want to do to help avert major problems is carry over as many electrical components from the Gen.1 to the other truck. Charging, injectors, etc. Check model numbers on components and similarities, you might be o.k. on more then not."
I'll post more as I get it.
__________________
'01 Lightning #761 of 6381 born 2/9/01
1973 F250 390fe - Gone
2000 Ranger 3.0 - Gone
