Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 11-23-2008, 02:43 AM
expy37at expy37at is offline
Garage is empty, add now
expy37at is starting off with a positive reputation.
Are 17" wheels avaiable on the Limited
Getting closer to buying another Expy and leaning toward the '09 because of what some here have said about the updated transmission.
One thing I need to know about the '09 Limited is if 17" wheels are available instead of the standard 18" ones..
I'd like the 17" wheels because I already have a set of tires set back, the tires are more readily available according to a guy at Sams, and I go on rough mountain dirt roads and want capable and easily found tires.
  #2 (permalink)
Old 11-23-2008, 05:20 AM
F-150 NiteMare's Avatar
F-150 NiteMare F-150 NiteMare is offline
F-150 NiteMare is new and has a neutral reputation at this point.
Ebay?!.... And probally only if you buy the XLT.
  #3 (permalink)
Old 11-23-2008, 08:25 PM
nckracer's Avatar
nckracer nckracer is offline
nckracer is starting off with a positive reputation.
From the mfg on Limited, only 18" are offered as the standard wheel and 20" are optional. Now the spare is a 17" when the 18" are installed on the ground.
My '07 had 18"s installed and I wanted 20"s. Word of caution: If you change wheel sizes from factory installed, you will also need to order the correct tire pressure monitors for each wheel. My local tire guy says the 18"s are very common anymore, he carries 20 different varieties of the 18" tire.
__________________
'11 Explorer Limited 4X4
'09 Expy Limited EL 4X4
'02 F-150 KR Crew 4X4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
